NEW EF-1 MOTOR APPROVED
IL
Guys,
Please use this post as notice to inform you that the NMPRA has approved the following motor for use in EF-1 contests:
Great Planes Rimfire EF1 Race 35-45-1250kV Outrunner BL
These motors will be listed on the Tower website starting later today (5/1/13). The rules will be updated later this year and currently do not reflect this change. Having said that, this notice shows that the NMPRA approved this motor and that it is legal for use in EF-1 contests.
Regards,
Dan Kane
Regards,
Dan Kane
RE: NEW EF-1 MOTOR APPROVED
Hi,
Can't find any specs on it yet at Great Planes or Tower.
Would you mind posting a few of the one you have like length from back to front of housing, diameter and weight?
Joe DeLateur.
Joe DeLateur.
Same mounting as the O.S.
Dia 35mm
Length 45mm
Kv 1250
Burst watts 1000
Weight 159gr
shaft Dia 5 mm
Input 7,414.8 (2S-4s LiPo)
Same size connectors as the O.S.
Max surge current 67amps
Dia 35mm
Length 45mm
Kv 1250
Burst watts 1000
Weight 159gr
shaft Dia 5 mm
