Graupner 1600-5 12volt motor to brushless??
I have an old graupner brushed motor that I am using a FX 35 digital ESC 50AMP. I am wanting to go with a brushless set up on an old graupner pylon plane and have no idea where to start as far as converting the motor and esc. What prop size would a person have used on this set up. I just bought it at an auction.
thanks |
RE: Graupner 1600-5 12volt motor to brushless??
1 Attachment(s)
Here are some pics I dont know what plane this is and the motor esc that I am wanting to upgrade. What prop and cell count would have been used on this brute?
thx |
What size is your plane, and what do you think its AUW might be?
Good heavens, that motor weighs 14.1oz!!!!! Graupner Ultra 1600-5 12V #1792 1180Kv 2.700amps 0.0800ohms 14.10oz For slightly lower weight you could get THIS: http://www.graupner.de/en/products/7...8/product.aspx .......and at 1200W that would surely tear your wings off. My feeling is that if you could find a far lighter 1200Kv motor rated for 500W-600W spinning a 10x8 perhaps, you'd have plenty of power. |
I am actually going to use the motor on my40 size telemaster and use it as a trainer for my 6 yr old. Thinking 11x7 direct drive on a 3s or 4s lipo. The plane that I had in the pics was an older graupner racer that was about 5.5 lbs with out the battery
