Electric RC Helis Discuss electric rc heli's such as the Piccolo, Logo 10, Logo 20, Hornet, Eco.
Which bearings wear out first on a 450 size heli
Reply
Old 03-30-2011, 08:53 AM
winginman
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Which bearings wear out first on a 450 size heli
What bearings in a 450 sized heli seem to need replacing earliest. (E-Razor 450, HK450GT, Belt-CP) I want to have some on hand when that happens. I looked at the exploded view and there are so many. I would bet some are more prone to wear (damage) than others. What experiences have you all had out there?
Anyone tried the ceramic bearings? Are they worth the cost?
winginman is offline
Old 03-30-2011, 09:33 AM
exeter_acres
exeter_acres's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Which bearings wear out first on a 450 size heli
Hmmm... flying a Trex for quite some time now...and never had a bearing issue.....
exeter_acres is offline
Old 04-08-2011, 08:23 AM
Beachcomber
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
After over 200 flights on my 450 clone, the only time I replace any bearings is after a crash. When rebuilding after a crash, I check bearings for notchy feel, and replace. Hard to tell if they wore out or were damaged in the crash. I'm guessing crash.
I've replaced a couple of tail assembly bearings after a tail first crash.
The most common to replace is the bearing on the inside of the blade grip, closest to the main shaft.
Once had to replace the upper main shaft bearing after a bad crash that bent the main shaft.
Hope this helps.
Beachcomber is offline
Old 04-09-2011, 04:47 PM
grawyl
grawyl's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The radial bearings in the blade grips and the Main shaft bearings will almost always go in the event of a crash. If you are going to get spares, that what I would get.
grawyl is offline
Reply
Display Modes
