Spektrum DX6i compatible helicopters
MA
RE: Spektrum DX6i compatible helicopters
Short answer ,, YES I have a Dx6i and I fly my Trex 450, 500esp & 550e Fbl all without any problems. You could also fly a nitro heli but you would not be able to use a govenor on the motor. So as my local heli shop guru Jeremy says you'd have to program the radio to fly a throttle curve like they did before govenors came along,, No big deal.
My recommendation buy a Dx7 instead, that way you could run a governed nitro heli if you ever wanted to. just my 2 cents
I think what you're asking is: can the Spektrum DX6i talk to other brands of radio, the answer is no. If you buy a brand of heli like E-Sky or Walkera, you will have to replace the receiver with a Spektrum receiver (or Spektrum compatible clone). All the other electronics on the heli (ESC, servo, etc) will work with any radio, as far as I know. Watch out for helis that combine the receiver with other stuff, like ESC, onto the same circuit board. That becomes harder (if not impossible) to change just the radio receiver.
NC
I don't know if this will work with the Heli Max brand of helicopters or not?
I know they are introducing this for airplanes, but maybe something in the future with the HeliMax brand?
http://www.tacticrc.com/tacj2000.html
