blades not spinning on back propeller
hi all can you please help me my back propeller is not spinning on my aerohawk electric heli the main propeller works but not the back one could you please tell me wot is the prob[:-][:@][>:]
RE: blades not spinning on back propeller
Are you sure all cables are connected? Have you taken a volt/ohm meter and found if there is current to the rear rotor? Also, it could be a burned out motor or speed controller...
