Hummingbird-Questions for upgrade
Alright,
do any of you know what the difference between the cf main blades helihobby sells http://www.helihobby.com/commonImages/CFiberMain.jpg (the first one on the list) and the one century heli sells (http://www.heli-world.com/Merchant2/...ct_Code=CNE062)
Please help me figure this out.
RE: Hummingbird-Questions for upgrade
Doesn't look like there is much difference but the helihobby one looks like it is slightly better designed.(century one looks like an exact copy of the stock blade)
The MS Composit FP CF blades(for the hornet) give much more stability because of an increase in head speed.
What is your setup though........................................
tomflier
tomflier
HOw much do these ms composite blades cost?
Also, are there any rubbers or screws I need in order for them to fit on the HB?
I tried to order them from Century before Christmas. I was told that they were out of stock and they had no idea when they would be in. I'd like to know if you can get them from Century, given the troubles helihobby seems to have right now.
