Question/Problem with HB CP2
My questoin is about my honeybee cp2. The Anti Rotation Pin on the swashplate keeps coming out of the Anti Rotation Support. This happens when I give the heli back cyclic control to the right. I can watch this happen with out the main baldes even turning. Not sure how much it effects the flight of the heli as I dont notice it all the time and Im able to still fly it. Any ideas on how to correct this problem. I tryed replacing it with a new one with no effect. The ARS isn't bent either. One thing I did know just notice is when I give it full back cyclic the pin is all the way out of the ARS. Thanks.
RE: Question/Problem with HB CP2
i have heard there is a replacement part available..........i just cyano'd a piece of carbon rod to lengthen the pin i wrapped it with carbon fibre too.............you could also put a spacer on the slot on the head side to prevent this.............my carbon rod fix is working great
