sjm 400 II main blades
WA
ok I got kinda screwed on a used sjm 400 II heli and need a set of main blades I know there arounf 305mm and 3mm wide but what other heli uses the same blades? the 3mm wide is the hard part so I'm told (and yes I know the a400 is the same) thanks
NY
RE: sjm 400 II main blades
Different blades can be used but for the original ones go to: http://www.rc-tek.com/
ORIGINAL: k_ogre
