New align motor quits
ME
I am using an align bl motor (3550kv) and a 25a esc. I will Idle up and get into a little hover and the motor will stop turning. I will turn the throttle all the way down and start up again and it will be fine. And so on. What does this usually mean? thanks
RE: New align motor quits
There is a high amp cut off on your esc, and you are hitting it. See if you can disable it by programing, if you can't get a 35 amp esc and all your problems will be solved. You might also lower the pitch on your blades, you will get higher head speed and draw less current.
GA
ORIGINAL: lwatson
Huh?
never heard of that....... I used a 25a on my Trex for a while. While it isn't the best (a quark 33 would be nice) it will work.....
ESC's will just fry if too many amps are put through them...
I am with PTB... it sounds like a low voltage cutoff....
what battery pack is being used....
the battery is the most overlooked, but most important part of the electric equation
I am sorry, you are right, it is a low voltage cutoff. But the battery drops voltage because a lot of amps are being drawn from it. So the effect is the same.
IN
Helitb,
Had the same on my Trex, bad battery.
Dave / Choppersrule
Dave / Choppersrule
ORIGINAL: HeliTB
I had the same symptoms with a bad battery. Once it had a load it would just stop. Without a load it seem fine.
