Airwolf 50size [Funkey]
Hi, i have a 50size Airwolf fuselage - Funkey. Need Kit to be electric config.. Any recommendations on which Electric 50 size kit is available? Hope u all may assist me. Thanks!
RE: Airwolf 50size [Funkey]
Thanks for the recommendation & information, appreciated it very much. And finally, I have decided to put RAZOR50size - Miniature Aircraft into the Airwolf fuselage. Already bought it, Did some fitting on the fuselage & it only need some modifications on tail boom, belt, and tail rotor system.. I only need to cut slightly wider hole in form of an oval shape near the swashplate area, to accomodate it & to ensure the top servos are fitted well. At base fuselage, will cut to fit a piece of balsa wood 3mm in thickness (epoxy coated) for strength. All else fits fine. The lighting system will use curteks. As for stock items of tail blade grip, main blade grip, mixing arms, will be upgraded with CNC parts. Infact, had specially made CNC rims with rubber tyres to make it more scale & still trying to figure out how to make a scale CNC retract.[] The recommended battery pack of 3700mAh will not be enough, so Flight Power - 4300mAh should be fine. I had chosen Razor50 coz, it one of the best 50size electric heli in the market at the moment. And I really enjoyed my ION-X. Happy flying.
