Multiple Heli's on 1 TX?!
My Spektrum DX7 is supposily capable of setting up multiple heli's on one TX unit, but it seems the original model data goes to "bit-heaven [:@]," when you call model 1 back up, or did I mess something up?
I went to set-up model 2 (a T-rex 500), named it, set-up the model parameters & bound the RX. Then I decided to go back to model 1, my MX300 (was an AXE CP), and all the set-up data was GONE! Thank goodness I wrote everything down after I had it set-up & flying well, but it still baffles me on what happened to all the flight parameters for model 1 [], and I'm I gonna have to do this every time I switch between the 2 heli's [:'(]?
How many others out there are using one TX unit on multiple heli's & is it as simple as calling up the model # and binding the RX then go flying?
Thanks Guys,
Shadow
Thanks Guys,
Shadow
IL
RE: Multiple Heli's on 1 TX?!
I have a DX7,and yes it is simple,once you get the hang of programming it. I was accidently hitting the copy model function,and wiping out my previous model in the TX. I have 3 jets(1 is a DF) 5 3-D planes,and a CX2 and BH450Se heli. in there. Still got 10 to go! Ron
Thanks Ron,
That's just the response I needed!
I must have done the same thing with the copy function (trying to save time w/ set-up), what's the purpose of a COPY function that DELETES as it copies? Maybe I'll continue to backup the model parameters to paper, just incase Murphy's Law shows up to help.
Thanks Again!
Shadow
Thanks Again!
Shadow
