Electric RC Helis Discuss electric rc heli's such as the Piccolo, Logo 10, Logo 20, Hornet, Eco.
is this ok?
Old 05-02-2019, 07:03 AM
Pegasus
Default is this ok?
I bought this from GOGO. RC, the stainless piece that holds the blade holders is not drilled straight, I was told this is ok, would you guys use it? You can see that the blades holders are not parallel with the v block behind it
Old 12-31-2019, 02:21 PM
cyclicoverload
cyclicoverload's Avatar
I would say no way, those tail blades will not track right and setup quite the vibration. I have bent the tail yoke (spindle shaft) and it had a crazy high freq vibration that freaked the gyro out.
Old 02-05-2020, 08:29 AM
white777
white777's Avatar
If there is no vibration it means that everything is okayif. Otherwise you should go to a specialist.
