GRC GT450v3 Build
GRC GT450v3 Build
This is more of an assembly thread rather than a build thread..
The GRC GT450v3 series is one that features good quality flying, With Advanced Flying Technologies built in, this model series will be a hit among rc hobbyists. This model consists of RTF equippment (Ready to Fly Equippment)
It works with 6 to 8 Channel R/C System
The main features are as follows:
1) Ultra tough carbon fiber main frame gives the Helicopter light weight and durability.
2) Tail Rotor Drive Belt System.
3) Unique dual-push tail pitch for smooth pitch travel and approach "zeroh tolerance controlling.
4jHigh Precision CNC-machined metal main rotor and tail rotor control group provides more operation accuracy.
Specifications:
Length:650mm
Height: 230mm
Main Blade Length: 325mm
Main Rotor Diameter: 710mm
Tail Rotor Diameter: 155mm
Motor Pinion Gear: 13T/14T
Main Gear: 150T
Balancer Diameter: 122mm
Main Drive Gear: 150T
Tail Drive Gear: 43T
Weight (w/o power system) 440g (15.5oz)
Flying Weight: Approx 730g(25.8oz)
Ready to Fly Package includes:
Li-Poly Battery:11.1V 3S 2200mAh / 20C
Brushless Motor: 3500KV powerful Brushless motor *1pcs
ESC: 35A Brushless ESC *1pcs
Gyro:GT210 *1pcs + digital tail servo 9g *1pcs
Servo: Gootch 9g servo (Metal gear) *3pcs
Standard Balance charger
100% Carbon Fibre blade *1pc;
canopy*1pcs
Specifications:
Length:650mm
Height: 230mm
Main Gear: 150T
canopy*1pcs
