Airbus A320 EPO
Airbus A320 EPO
Yesterday someone posted about an Airbus A330, today Hobbyking has a new Airbus A320 on their website: http://www.hobbyking.com/hobbyking/s...dProduct=13845
Specifications:
Price is US$ 216.45
Specifications:
Length: 1440mm (56.69in)
Wing span: 1540mm (60.62in)
Flying weight: 1850g
Motor: 2839 Brushless outrunner (3200KV)
ESC: 2 x 45A
Servo: 9g * 5pcs
Battery: 3300mAh 4S1P 25C Lipoly Pack (Not Included)
EDF Diameter: 2 x 70mm
ESC: 2 x 45A
Servo: 9g * 5pcs
Price is US$ 216.45
My Feedback: (7)
TX
RE: Airbus A320 EPO
plane-addict,
Here is the post you were talking about:
http://www.rcuniverse.com/forum/m_10...m.htm#10033022
Our A330 is based on the -300 version. The fuselage is constructed from carbon reinforced epoxy resin glass in a three piece layout for logistical packing and has a balsa rib and spar construction wing with balsa sheet covering and finally an Oracover surface. It will be offered with a fixed gear, oleo undercarriage although the initial photos taken show the optional, fully retractable, scale bogies and nose gear. Instructions for gear doors will be incorporated in this ARF kit. The wing airfoil has been carefully chosen to provide as benign flight characteristics as possible without detracting from scale dimensions and incorporates fully functioning trailing edge flaps. The aircraft flys in a very scale fashion and with plenty of excess thrust on two 70mm fans on 4S batteries producing around 1kg of thrust each and offsetting the AUW of approximately 4.5kg.
...the standard kit... includes; 2 HET 6904 70mm fans, 2 HET Typhoon 2W20 motors and 2 HET 75A speed controllers allowing you to add servos, a receiver and head to the field. Price - $1,495
a 2m long, 2m wingspan aircraft with epoxy resin fuselage, balsa rib and spar wing.
Here's the companies site:
http://www.setthrust.com/
RE: Airbus A320 EPO
@djsqueeze: Sorry for my late reply. You have a nice plane there! Price, but of course also quality, between yours and HK's is not comparable of course.
@Hobbyking now has a USA warehouse, there they have products that can't be shipped from Hongkong (among other products). Here is a link to the Hobbyking USA section: http://hobbyking.com/hobbyking/store...obby_Warehouse
I didn't find the A320 there, but for example, the A380 is available there: http://hobbyking.com/hobbyking/store...dProduct=14509
Maybe the A320 will make it to the USA warehouse too
