BH F-16 70mm with VT ( HELP )
I almost have this thing ready to test fly, and just had a couple questions for someone who may have this model.
1.) Do you fly it with the armerment attached ? If so is there any noticeable air grabbing, or flight trim variances ?
2.) The flight vid. of the stock set-up on the website appears to be pretty respectable, do you agree ?
3.) I have an 8ch. rx in the plane, and would like to have the VT feature on a aux switch. How did you go about doing this with the supplied electronics, or did you master/slave everything through a mix ?
" Pattern flyers make REALLY SMOOTH passes "
