Sky Angel F-16 EDF
Sky Angel F-16 EDF
Hi everyone:
I purchased this EDF from hobbyking a few weeks ago and i have been flying it non stop.. It's very fast and nimble.
But the one draw back i have is that the stock battery it brings is only 11.1v 850mh and the area for it is very very small... I have other 11.1 batteries but they're way way bigger in size,height and width.
Anyone know where i might get another replacement battery or maybe another battery that might fit where the stock one is?
I contacted hobbyking but all i got was an auto-reply and that was 4 days ago...
My Feedback: (7)
TX
RE: Sky Angel F-16 EDF
Night Scream,
Check size of your batt. then go back on their site and see if you can find one the same size. If not, check here:
http://www.okhobby.com/category.php?id_category=68&p=2
http://www.leaderhobby.com/
http://www.venom-group.com/storeitem...eries-Chargers
http://www.hobbypartz.com/
http://www.advancedbatteryfactory.com/
UT
You may check out http://www.all-battery.com/20cli-polymerpacks.aspx, I think you can find anything you want for a battery here. Good luck!
Thank you guys.
I'm just gonna be measuring and then deciding which pack to get..
Right now i got narrowed it down to 4 packs.. just need some final measurements..
Hi everyone:
The fan inside my f-16 broke in flight and i'm in serious need of just the impeler fan.
All I have been able to find is in bananahobby has the full edf unit minus motor for $5.00
Will that fit this plane? since all i need is the fan?? the housing and motor are both in perfect condition.
Also the original fan has a mini nut in the middle that screws on counter the rotation of the motor.. is that normal?? and will the replacement fan bring it?
Thank you
Thank you
Well sadly i'm in no luck of finding this impeller...
bananahobby wants to charge too much for shipping to where i live..
Hobbyking has non in stock and no idea when they'll have it back..
And every other place on the net that says that has it its in backorder with no reply on when they'll have it again..
I saw a edf of 49.2mm in towerhobbies.. will this work on my jet?
Any ideas would greatly help.. i like flying this jet but i'm grounded on it cause i can't find the part...
