Electric RC Jets Discuss rc electric ducted fan or radio control prop jets here.
Yellow Aircraft Sting Ray Build EDF
Reply
Old 07-24-2012, 01:13 PM
steveair2
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Yellow Aircraft Sting Ray Build EDF
Nice Work
Now tell me,You didn't spray all that plane with the airbrush you have on the table did you?
Cheers
Steve.
steveair2 is offline
Old 07-25-2012, 04:41 PM
juanjulian
juanjulian's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
What can I tell you. It sucked spraying the primer with this litle airbrush one inch at a time. Can´t complain about the airbrush it has done the work with honors.
Already ordereda mini gun to do the paint job.
cheers,
Juan
juanjulian is offline
Old 01-13-2013, 07:40 PM
juanjulian
juanjulian's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Like I read in another forum " this project is like watching grass grow"
After christmas started preparing for painting masking all the lines. A weekend working intemitently.
This weekend prepared my garage for painting. Had to put some anchors in the ceiling to hold some wire to help in the painting.
Got the oportunity to try my new gun a eastwood minimgun. Is not a sata but worked ok. The best part id the deckups which worked like a dream. Is tedius cleaning the gun or airbrush.
So some pictures of painting
[IMG]http://i1161.photobucket.com/albums/q512/juanviviana/Snapbucket/208D1927-or
Old 01-13-2013, 07:51 PM
juanjulian
juanjulian's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You are suppsed to pull of all the paper and masking tape before the paint cures. Dont't know how they do it with out ruining the paint jop. Messed up a good work in a a wing panel doing it. Also got some greasy fingers fingers spots.
The goodthing is that can be fixed.
This is fuselage after striping paper and masking tape.
Being this my first paint job with a auto paint gun and a big jet model I'm happy with the results.
The paint used is omni ppg one coat. PU
cheers
Juan
Old 01-14-2013, 12:38 AM
steveair2
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Nice one
your definitely getting there.
A big difference with that spray gun I would say.
Cheers
Steve.
Old 01-14-2013, 08:03 AM
  #31
Mustang Fever
Mustang Fever's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
That's beautiful, Juan.
Don't feel bad about taking your time- I started my Phantom last spring and it's only gotten this far. (90mm EDF Dan Savage model. I'm doing it as the first F4H-1 that flew in May, 1958.)
I won't be able to afford the radio until maybe May, so it won't fly for awhile. (I'm getting a Futaba 8J and a GYA 430 rudder gyro for it.)
ID:	1840313   Click image for larger version
ID:	1840314   Click image for larger version
Mustang Fever is offline
Old 01-19-2013, 01:41 PM
  #32
BadLemon
BadLemon's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Juan
Nice work on your Sting Ray I like you choice of color will look very nice in the air! I'll keep watching!
Doug
BadLemon is offline
Old 01-20-2013, 06:48 PM
  #33
juanjulian
juanjulian's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks for your coments Doug,
Aplied the color red today. Pending only them blue and metalic grey for for canopy.
Since his color is only on the bottom and canopy frame and motor bay used a pascche single action airbrush.The hobbicio airbrush uses a ruber oring that does not like lacker solvents and starts spitting paint. This new one uses a plastic intead of oring and is esier to clean.
My wife was not happy with the big mess I did last time painting with the new gun. Think 2/3 of paint go elsewere and not the object intended to paint. So this time they were not so happy of me painting in the garage.
after
Old 01-20-2013, 06:51 PM
  #34
juanjulian
juanjulian's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
After taking off all paper and masking tape. This time I was extra carefull in not ruining the work.
cheers
Juan.
Old 01-28-2013, 11:42 AM
  #35
BadLemon
BadLemon's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Juan
To Help with over spray You can make a simple spray booth out of some plastic, wood strips, adhesive backed Velcro, 2 furnace filters and a box fan. I made 4 = 8' X 8' plastic panels attach to 2 strips of wood on each end. Roll up the panel and make a strap out of velcro and attach to the top side of the wood strip. I screwed each panel wood strip with the velcro strap to the ceiling to form a 8' X 8' box. Then I put velcro on the plastic at the end of each panel to make a seal. I traced an outline of the furnace filter on each side of the plastic panels then attached the velcro inside the traced line. Then I cut out the plastic inside the velcro box and apply more velcro to the furance filter and stuck it to the plastic.
I then stuck the box fan to the to the outside of the plastic with velcro. While I painting I kept a spay bottle with water and sprayed the furnace filter this helped to catch the paint I also sprayed the floor to keep paint off of it. Just make sure all power cords are hung up out of the way of the water. Then when you are done just remove the fan and filters pull apart the velcro and roll up the panels then secure them with the velcro straps. I'm going to make another spray booth that will be 10' X 10' so I can put a table in to mix paint and use as a work surface in a few weeks I can takes some picture of it if you want. I estimated the cost should be about $80.00 to build getting everything from a walmart store.
Hope this helps
Doug
BadLemon is offline
Old 04-02-2013, 11:11 AM
  #36
juanjulian
juanjulian's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
This time can say I´m on the final leg to finish this plane.
To manage over spray this time put more plastics, and sprayed neerer to the wall for paint to sick there and not all over the place.
Took sevaral hours of sunday to cover with paper all the areas already painted. Was to late to paint sunday so this paint job was done monday.
Very happy with the results even knowing I messed up in several places. Will fix it up later.
ID:	1869450   Click image for larger version
Old 04-02-2013, 11:13 AM
  #37
juanjulian
juanjulian's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ID:	1869452   Click image for larger version
ID:	1869453   Click image for larger version
Old 04-02-2013, 11:34 AM
  #38
Mustang Fever
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I like it!!!
Old 04-02-2013, 11:49 AM
  #39
juanjulian
juanjulian's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks Bob that was a fast response.
Did you maiden your Phantom?
CHeers
Old 04-02-2013, 05:28 PM
  #40
Mustang Fever
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Not yet. Weather still cold and very windy. Waiting for some connectors from Tower Hobbies, also.
Old 05-14-2013, 12:27 PM
  #41
juanjulian
juanjulian's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
This bird is almost ready to maiden.
The painting, color sanding and polishing has ended. Need to confess that paid for the color sand and polishing of airplane.
This weeken glued the ailevators and ruders, and did all the links from servo to surfaces.
I'm not happy of how the instructions tell you to mount servos for rudders and ailevators. They are not 90 degrees with hinge line so you must use ball links to compensate. I noticed this to late. If have to build this again will modify servo location to be 90 dgrees with hinge line.
Yesterday conected rx to wiring harness and dialed in tx all movemts of flying surfaces. Did a test run of airplane infront of my house. My watt meter burned just by connecting to batteries. So could not measure peak watts and amps. I suposely balanced fan using only 6s battery but this time on 12 s found a harmonics vibration at mid throtle. It is scary pushing the fan to 100% throtle for the first time.
Only need to glue the rx battery to the nose of plane to balance properly.
Think will maiden next week.
Cheers
Juan
Old 05-14-2013, 12:46 PM
  #42
juanjulian
juanjulian's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ID:	1881959   Click image for larger version
Old 05-14-2013, 04:17 PM
  #43
Mustang Fever
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Old 06-03-2013, 05:01 AM
  #44
stoneenforcer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
stoneenforcer is offline
Old 06-24-2013, 06:05 PM
  #45
monkeyking
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi!
What about the maiden???? do you have photos/video???
I have one Stingray that I bought to a friend of mine few years ago...
I was using a JetJoe but I had some problems with it... so I sold it and I am looking to a Kingtech...
I will post some photos... it is very very well done!
Hope to hear from you soon Julian.
Saludos!
Mauro.-
monkeyking is offline
Old 06-25-2013, 11:29 AM
  #46
monkeyking
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
some videos of mine...
https://www.youtube.com/watch?v=99-jVyC-m6Y
https://www.youtube.com/watch?v=dr3no5CegjE
Old 06-28-2013, 01:29 PM
  #47
juanjulian
juanjulian's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hola Mauro:
I have seen that video several times. Nice to know it still flies. I like the design and colors or your sting ray.
I had the intentions to maiden two weeks ago but the electric motor failed during the test runs.
The fan had a very bad armonic vibration at 3/4 throtle that could not fix balancing again the fan. Attempting the balance fan after several test the fan started making a cliking sound before coming to a stop. To make things short the motor has bad bearing and it was new but stored for two years.
Have to buy new motor to maiden,o have to wait for the new motor.
Kintech has a new small turbine very interesting for this plane.
Cheers
Juan
Old 06-28-2013, 02:17 PM
  #48
Mustang Fever
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Juan: That's a 90mm fan isn't it? I'll sell you my RC Lander 90mm for half price if you're interested. (The one from the F-4. It didn't get hurt in the crash as it was way in back away from all the excitement, and it ran perfectly during the flight.)
Old 06-29-2013, 06:33 PM
  #49
juanjulian
juanjulian's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Bob
For how many cells is your fan speciefied and kv of motor?
I want a high voltage low amp draw to get the power for this plane. At the moment my intentions are to use 12s for a 1130 kv motor. This plane is 13 pounds so i' m in the higher wheight range.
cheers
juan
Old 06-30-2013, 04:52 AM
  #50
Mustang Fever
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Mine wouldn't work for you, Juan. It generates about 6 pounds on 6 cells. About half what you'd need.
Reply
Display Modes
