Go Back  RCU Forums > Electric Aircraft Universe > Electric RC Jets
Reload this Page >
New Jet Blohm & Voss P-214 / P-212
Electric RC Jets Discuss rc electric ducted fan or radio control prop jets here.
Old 04-24-2011, 05:19 PM
Vulture33
Vulture33's Avatar
Default New Jet Blohm & Voss P-214 / P-212
So I decided to scratch build a Blohm & Voss P-214 / P-212 with a left over 50 mm EDF motor from an Alpha jet that had crashed. I drew the pictures from drawings I downloaded from www.luft46.com - I used the actual airfoil enlarged in thickness and about a 2" additional wingspan. Other than that, it is pretty close to the original. This was my first scratch built from foam airplane and I ordered a wire cutter to make the wing. The fuselage I made from blue foam and a small wire cutter from Michaels arts and crafts.
I used HiTech HS 55 servos and a spectrum park flier receiver. 1300/11.1 volt battery and 40 amp speed controller. Elevons only for control. I have not put this plane on a scale but it balanced perfectly right out of the gate.
The first flight was today into about a 7 mph wind... I threw it and it was on rails right from the start. I figured that it was going to crash or if not crash... fly great. Thankfully it flew great. The video is a bit ADHD but you get enough of the plane to get an idea of how well this plane flies.
http://www.youtube.com/watch?v=Mwz9RycwozM
ID:	1598581   Click image for larger version
ID:	1598582   Click image for larger version
ID:	1598583   Click image for larger version
ID:	1598584   Click image for larger version
ID:	1598585   Click image for larger version
ID:	1598586   Click image for larger version
Old 12-09-2018, 08:29 PM
Richbailey
Hello Vulture
Rich here. Am building The 215, using blue building foam board. 65 “ ws. 90 mm edf. Wings cut to shape. Made foam cutter, starting on fus next.
Any comments.
Rich
Old 12-10-2018, 09:12 PM
Richbailey
Hello vulture. Am building a Blohm & Voss 215. How did you get the intake cut in the foam? Did you make a ply template?
Rich
Old 12-12-2018, 10:03 AM
Richbailey
Hello Vulture. How did you cut the full length intake?
rich
