Go Back  RCU Forums > Electric Aircraft Universe > Electric RC Jets
Reload this Page >
RClander T33 for 90 or 120mm edf
Electric RC Jets Discuss rc electric ducted fan or radio control prop jets here.
Old 05-28-2012, 06:11 PM
  #126
mavdriver
My Feedback: (14)
Default RE: RClander T33 for 90 or 120mm edf
all i can say you better beef up the T33 airframe i really dont think it can handle the extra power from the BVM set up , you might get away with 10s but 12s might push the airframe , after all , is a foam yet my bud flys an BVM Electra on 12s and his easyly doing 200 mph plus , just something to think about foam is not as good as fiberglass unless the fuse is mixed in Carbon fiber .
Ed
Old 05-29-2012, 03:19 PM
  #127
Greg Covey
Greg Covey's Avatar
Post #30 shows several photos of my Lander 120mm installation. I would expect the BVM system to be similar size.
You could test the system on 10s and see if you come close to my 4000 watt setup. It would be a good start and provide more power than you will need...even off grass.
Good luck!
Old 05-29-2012, 03:30 PM
  #128
frankensteen
Thanks guys-10s with the EVF2 would be the way to go, maybe with some CF cloth to beef it from the inside.
Old 05-29-2012, 03:43 PM
  #129
frankensteen
I had this EVF2 in a 22 pound NTech F9F Panther, but just not enough power for it. Its got a cut down dynamax rotor, so would sound incredible in the T33 i suspect. Do you think the intakes would be big enough?
Thanks again...
Old 05-30-2012, 02:53 PM
  #130
Greg Covey
Greg Covey's Avatar
My T-33 has a 120mm DF in it. Did you watch the video off grass in post #123 or the maiden flight off pavement in post #109?
All you need is a bell shaped opening to flare into the side walls and you'll be all set.
Old 05-30-2012, 03:28 PM
  #131
frankensteen
Just checked it out-thanks Greg. Your T-bird T33 looks and flies great! I think I'll give the T33 a try...
Old 06-02-2012, 11:15 AM
  #132
frankensteen
Was there supposed to be a PC covered version coming out? Can't find info on it...
Old 07-02-2012, 03:06 PM
  #133
Greg Covey
Greg Covey's Avatar
I friend taped our T-33 take-off from grass at a local R/C show a few weekends ago. I had one of the gear mains disconnected for repair but the T-33 still flew and sounded great! Since my pack capacity is only 3.6AH, I place the T-33 at the end of the runway instead of taxiing it out.
[link=http://www.gregcovey.com/Reviews/T33Flying4.wmv]T-33 Grass Takeoff at RCCR[/link] (3meg)
Old 07-20-2012, 10:56 AM
  #134
Greg Covey
Greg Covey's Avatar
My stock inrunner blew out so I replaced it with the Turnigy [link=http://www.hobbyking.com/hobbyking/store/uh_viewitem.asp?idproduct=19111]SK3[/link] Fandrive motor which I detailed a few pages back starting in Post #60. The power increase was very noticable and we had a great flight as shown in the video below. I hit the wrong button on the video camera and lost some sound on the taxi out.
[link=http://www.gregcovey.com/Reviews/T33Flying5.wmv]T-33 Flying with Turnigy SK3 Fandrive[/link] (20meg)
Old 07-21-2012, 05:33 AM
  #135
Greg Covey
Greg Covey's Avatar
Here is the Castle Data Logging from my flight with the new Turnigy SK3 Fandrive motor. The power level is about 5300 watts at 130 amps using normal timing with my two 6s Turnigy 3.6AH packs. Cruising speed was about 2800 watts at 64 amps. The flights are a short 2.5 minutes with 20% left in the pack.
I may change the timing to low since I have more power than needed and buy some bigger packs. I think the T-33 is easily capable of handling more weight.
Old 07-22-2012, 11:08 PM
  #136
tim wan
This is an update information of our new rubber tires for brake system. Those are come with two sizes 2.75 & 2.5 inch.. Yesterday I have done the test of those performance with our T-33 . During the testing, It can be let the brake system function perform very well and better than PU foam tires version. The following is the link for sharing with you.
http://youtu.be/PaHg9Je4Ekw
BRs,
Tim
<o></o>
ID:	1784654   Click image for larger version
ID:	1784655   Click image for larger version
ID:	1784656   Click image for larger version
ID:	1784657   Click image for larger version
ID:	1784658   Click image for larger version
ID:	1784659   Click image for larger version
ID:	1784660   Click image for larger version
ID:	1784662   Click image for larger version
Old 07-23-2012, 08:16 AM
  #137
Greg Covey
Greg Covey's Avatar
Hi Tim,
The new rubber tires look great! They should handle the weight of the plane much better on those not so perfect landings. The breaking system is a must have option for short paved runways.
On my grass field landings, the T-33 slows up nicely without brakes.
Best Regards.
Old 07-24-2012, 03:24 PM
  #138
Greg Covey
Greg Covey's Avatar
Here is a short HD video of the T-33 take-off, roll, and landing on grass. With no wind, it floated in nicely on full flaps!
[link=http://www.gregcovey.com/Reviews/T33FlyingHD1.wmv]T-33 Flying with Turnigy SK3 Short HD Video[/link] (35meg)
Old 07-27-2012, 03:43 AM
  #139
Greg Covey
Greg Covey's Avatar
Here is another video of the T-33 on a brighter day flying in Canandaigua, NY in the Finger Lakes Region. This time, Lynn Bowerman took the sticks. The landing was a bit hard, but not bad, because we had only half flaps. Normally, we have been using half flaps for take-off and full flaps for landing.
[link=http://www.gregcovey.com/Reviews/T33Flying6.wmv]T-33 Flying with Turnigy SK3 Fandrive 2[/link] (11meg)
Old 07-28-2012, 03:54 AM
  #140
Greg Covey
Greg Covey's Avatar
Here are some photos from last weekend's flying...
photos by "Papa Jeff" Ring
ID:	1786706   Click image for larger version
ID:	1786707   Click image for larger version
ID:	1786708   Click image for larger version
ID:	1786709   Click image for larger version
ID:	1786710   Click image for larger version
ID:	1786711   Click image for larger version
ID:	1786712   Click image for larger version
ID:	1786714   Click image for larger version
Old 07-28-2012, 08:13 AM
  #141
Greg Covey
Greg Covey's Avatar
Here is the Data Logging from the last flight. Most of it was spent cruising around at about 1400-1500 watts. I changed my ESC timing from Normal to Low so we'll see what the take-off power reads on the next flight.
Old 08-07-2012, 07:21 AM
  #142
wind junkie
Looks awesome Greg. I'm happy to see a jet take off and land from a grass field without issue. Looks like you have the LG/retracts ironed out.
Joe
Old 08-08-2012, 03:10 PM
  #143
Greg Covey
Greg Covey's Avatar
Thanks, Joe. You definitely need the right combination of power, weight, wing-loading, and wheel size for taking off grass. The vintage design T-33 had some real wheels under it.
Regards.
Old 08-28-2012, 07:42 AM
  #144
Henke Torphammar
Henke Torphammar's Avatar
ORIGINAL: Greg Covey
Regards.
For takeoff when the EDF still deliver it's massive static thrust it goes better then the turbine version, while in the air you nitice very little diffrences.
Old 09-09-2012, 01:46 PM
  #145
Hellcat716
Hellcat716's Avatar
Flew flight number five today. On landing the right plastic wheel hub came apart on a soft landing. The wheel came off the plastic hub since it broke apart. Wondering if there is a better hub available that will work withy this set up. I have tried severl manufactures but the inner gear door will not close correctly. The other issue is the right retract will not extend all the time. I have to tap the retract with a screw driver several times than it will work. I can not tap the retract while in flight. Any suggestions what needs to be done. Possibly a bad circut board. Max told me I have the new generation retract. Not sure they have been fix correctly at this point. Other than that, a great flying plane.
ID:	1799582   Click image for larger version
ID:	1799583   Click image for larger version
Old 09-09-2012, 02:59 PM
  #146
Parkflying
ORIGINAL: Hellcat716
We have metal hub tires, with or without the RCL Brake System that should work. ALSO if you have a problematic Retract Unit return immediately for replacement. You know we protect our buyers from factory defect. We now have only the latested updated versions that are showing greater reliablity. These can be identified easily as they have only 3 screws on each side plate and not 4 screws on each side plate as the original versions did.
Contact us directly at our website or my email
[email protected]
Regards
Max
www.parkrcmodels.com
Old 09-16-2012, 03:31 PM
  #147
Free Bird
I saw Greg's T33 fly at the Noon Demo at the Neat Fair this weekend. To say it was impressive is an understatement! The grass runway is pretty thick there and the plane had no problem getting airborne. It was also pretty windy and the model handled it well. Seeing pictures of the model doesn't give you a true feel for the size it, in person this thing is huge! But to me, what was most impressive was the sound, it didn't have the typical high pitch whine of an EDF, but it had a fabulous 'whoose' sound that was incredible! Oh yeah, it was also fast! Great job Greg!
FB
Old 09-18-2012, 03:44 AM
  #148
wind junkie
I agree Free Bird. I think Greg's was my favorite plane at the event.
Joe
Old 09-18-2012, 07:03 AM
  #149
Greg Covey
Greg Covey's Avatar
Thanks guys! I could relax and just watch it go with Team Futaba's Devin McGrath on the sticks. I'm always surprised that there are not more EDFs in the noontime demos.
I'll post some photos and video of the T-33 at NEAT soon...
Old 09-20-2012, 01:17 PM
  #150
rfodor
Greg, how is that SK3 Fandrive working? Have you tried it on low timing yet, if so how much current/watts? I burned my 830KV inrunner up on the first flight with my original Lander 120mm. I have a SK3 in shipment from China. I am using the fan in a Yellow A4 and the original motor powered it very nicely until the pilot turned the smoke on LOL. had to dead stick it in the grass but got away with no damage. I tried to buy a Leopard 4475-830KV from Leopard but they no longer make it with a 6mm shaft so, I'll try the SK3 and bore out the shaft to 8mm.
