Electric RC Jets Discuss rc electric ducted fan or radio control prop jets here.
New Change Sun 70mm 10 blade fans
Reply
Old 12-01-2011, 10:32 PM
raido56
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: New Change Sun 70mm 10 blade fans
OK, Heres my C/S 10 blade fans mounted in my Super Airliner ready to go. Hope to get her up in the air this week.
Keep em flying
raido56/ Herb
ID:	1694032   Click image for larger version
ID:	1694033   Click image for larger version
ID:	1694034   Click image for larger version
raido56 is offline
Old 12-02-2011, 05:47 AM
erh7771
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: raido56
Keep em flying
raido56/ Herb
This is the best use of these fans for me cause with two of them going at least you can hear them.
They're quite, very quite relative to other fans and I like to hear how my jets sound
erh7771 is online now
Old 12-02-2011, 05:57 AM
dionysusbacchus
dionysusbacchus's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: raido56
Keep em flying
raido56/ Herb
Looks great Herb, good luck, I'm sure it will sound and look great in the air!
I still am looking for the best motor to buy for this fan, using a 2800kv motor and 4s 3300 30c pack with an 80amp ESC I run out of throttle at about 75 percent, but my Venom F-86 flies great at half throttle. My question is, why does my throttle have nothing after 75 percent, what is missing? I'm new to this so I would really appreciate some advice, I don't want to spend a fortune buying motors and batteries to test in this thing. So any advice from real world experience would be great.
Luke
dionysusbacchus is offline
Old 12-02-2011, 06:34 AM
gary41
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Luke,
Did you calibrate your ESC to the Xmeter's Channel 3?
gary41 is offline
Old 12-02-2011, 07:30 AM
dionysusbacchus
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: gary41
Luke,
No I did not, what exactly do I need to do? I wanted to order the programming card for my ESC but they are sold out, the beep thing just does not work for me!
Old 12-02-2011, 09:48 AM
  #31
gary41
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Others may correct me.......but, as I recall:
Throttle full up, turn on transmitter
Apply power to ESC and receiver
ESC will emit a tone
Move throttle to minimum
ESC will emit another tone
Remove power from ESC and receiver
Turn off transmitter
You're done.
gary41 is offline
Old 12-02-2011, 11:33 AM
  #32
dionysusbacchus
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks Gary, I'll give it a try and see what happens!
Old 12-05-2011, 04:50 AM
  #33
raido56
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: erh7771
Quote:
ORIGINAL: raido56
Keep em flying
raido56/ Herb
Hi all, I had her maiden flight on Sat with the C/S 10 blade fans. She took off real nice from our grass field. Full power on take off than down to half power for most of the flight. Rolls, loops even knife edge no problem. She has real good power way better than the 3 or 6 blade stock fans. Ran the motors on 2- 3s 2650 40C packs and getting 4 min on the packs. After I get the retracts in it I will be able to use some 3000 or 3300 packs and get about 4 1/4 to 5 min out of her. I have to say the sound from these fans are better than the stock fans. I don't get the woosh sound like other have gotten in a long ducted jet. I think it's because of the short nacelles and lower RPM's from the 3s packs. But it does look real neat with all them blades in the fan. Had a few flights today also. My buddy took a video of one of her flights today so as soon as I get it from him I'll post it.
Keep em flying
raido56/ Herb
raido56 is offline
Old 12-07-2011, 11:19 PM
  #34
raido56
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi all, My buddy shot this video of her maiden flight. This flight was on 2-3s 2650 40C packs. I like the take off from grass on the stock wheels. (NOTE) The rate she climbed at after take off I like it for sure .. Plus the winds were about 10 MPH with the stock fans I would not fly her when it was windy as she would get pushed all over the place. With these fans no problem at all. I hope to get a better video this week with my HD cam. After that I will try to get the retracts on her and new paint job sometime later.
Keep em flying
raido56/ Herb
http://youtu.be/l4b8UtZQ7Qc
raido56 is offline
Old 12-08-2011, 03:40 AM
  #35
dionysusbacchus
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Video was hard to watch, seemed jerky, but I could hear the fans. The motors have just as much to do with the sound as the blade count I've found. The motors with the open back are much louder than the ones with an aerodynamic shroud, and yours seem very loud because you have no tail pipe. I know this because I experimented with a few different configurations and the Turnigy motors produced the least noise.
Old 12-08-2011, 04:43 AM
  #36
Greg Covey
Greg Covey's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
[link=http://www.pw-rc.com/index.php/cPath/131?osCsid=7fd74792730d0f617f7e2c6dbc8504ce]Philip Workshop RC[/link] sells both the new 70mm and 90mm CS DFs. The 120mm DF should also show up shortly. The registered Air Mail option is very low cost and only takes about a week.
Greg Covey is offline
Old 12-20-2011, 07:33 PM
  #37
jetjky1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi. I'm really excited to get my 70 mm now for my windrider 737-700!! My question for you is what motors do you think would produce the most scale sound and power...in runner or out? If so, what kv would you suggest for a 4s 3850 setup? I have two E-Flight power 15 3600 kv in runners, but I think the amp draw will be far greater than my het 75 amp esc's could handle. I am trying to stay with my 75 amp esc's if I can. The all in weight of the 737 is around 6.5 lbs. I also live in Colorado at an elevation of 5280 ft.
Any suggestions would be greatly appreciated.
Thank you for the great posts.
Jeff
jetjky1 is offline
Old 12-21-2011, 03:28 PM
  #38
Extreme_RC
Extreme_RC's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quality inrunners will always be superior in sound and efficiency, most outrunners whine when running, and ruin the sound of the fan. A good inrunner in an alloy housing with the 10 blade rotor is still the best sounding setup so far imho.
Oh an no offense Herb but that airliner sounded awful, could hear rubbing at certain points in the rpm range and the fans sound sick, like there is something wrong.
Extreme_RC is offline
Old 12-21-2011, 06:00 PM
  #39
dionysusbacchus
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: jetjky1
Jeff
This is a video of a completely stock ChangeSun 70mm fan and a $13 2800kv outrunner Turnigy motor. Sorry about the wind noise, it was pretty gusty last weekend.
There are some on this site that use it to promote there products and will never give anyone any assistance or any usable information, but from what little I know I would say to go with a lower kv motor for these fans.
[youtube]http://www.youtube.com/watch?v=AlJChzxAn38&context=C38f5b66ADOEgsToPDskJyzUxbsAEIs-4INUN1WjLi[/youtube]
Old 01-11-2012, 11:34 AM
  #40
fred685
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Seems like people are happy with this fan. Not sure why mine does not work well. I have a RC Lander Cougar that has scale intakes, fiberglassed and retracts. It's a little over 4 pounds. I flew it all year with a Jetscreamer/ Wemo setup on 4s. Takes 300 feet or so to get off the ground and flies fairly well once up to speed. This past week, I switched the Wemo out for the CS 10 blade. Watts are about the same as the wemo (1400), but the airplane can not get enough speed to take off. Holding the tail, it's obvious there is no where near the thrust compared to the wemo. Could this fan need more intake than the wemo?
Any opinions?
fred685 is offline
Old 01-25-2012, 05:28 AM
  #41
Glacier Girl
Glacier Girl's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Fred what are the kv specs of the motor. You went from what a 3 or 5 blade unit to a 10 so it could be the motor is now the weak point. Not enough grunt to effectively spin the fan or a pack that can't deliver the amps needed.
If the watts stayed the same, I'd be looking at a motor or pack for a problem. I would think if it was pulling 1400 watts on the lower count fan, it should have gone much higher on a 10 blade.
I would think just like a prop job, the more blades you have the higher the amp draw, and watts produced, if the pack and motor are up to it.
Just for S&G's I used Motocalc and plugged in one of my P-38 specs. Went from a 3 blade to a 10 blade, amps doubled, and watts went up by 50%. Thrust doubled, and prop speed dropped roughly 30%.
Glacier Girl is offline
Old 01-25-2012, 05:50 AM
  #42
Glacier Girl
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Luke, nice video!
Seems like from what I've been gathering over on RCG, where there is a big thread running on this fan, lower kv units and higher cell counts seem to be the trick.
I'm leaning towards a 2100 kv motor set up, on a twin. Can run it on 4/5/6S set ups, and go from 450 watts per unit to over 1200 with just swapping out pack counts.
Even at 1200 watts they are only pulling 50 amps.
Funny it's like my old Stryker days, where I used low kv motors on high volts to spin up a big prop fast. Go the best of both worlds that way, had tons of thrust and speed, and low amp draws.
Old 02-09-2012, 11:16 AM
  #43
extra 300
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: dionysusbacchus
dionysusbacchus,
I am looking to use 2 of the 10 blades fan, suitable turnigy motor, 70 Amp Turnigy ESC and 2 x 4S batteries for the Settrust A330 2 x 2 meters and 4.5 kgs (which uses 70mm fans). The required thrust is around 1.1/1.2 Kgs per power plant. A little more would not hurt as long as i come up with a reliable setup. Will the recomended turnigy 2855-2100 (450W) or alternatively Turnigy 2855-2800 (631W) be a good choice or do you suggest some other motor.
Thanks much for the help.
Best regards,
extra 300 is offline
Old 02-09-2012, 11:18 AM
  #44
extra 300
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
double post....
Old 02-13-2012, 03:58 AM
  #45
dionysusbacchus
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The Turnigy 2855-2100 is rated at up to 6s, the 2855-2800 is up to 4s, two 3s packs and the 2100kv motor will be more than enough for your requirements in my opinion. I recently converted my ChangeSun 70mm F-86 to a 6s set up using the Turnigy 2100kv motor and it runs great! I will post a video of the flight test as soon as the weather is favorable. At full throttle it stabilizes at 60 amps and 1495 watts. The motor runs smooth and the fan and motor were well balanced right out of the box. I would definitely go with a lower kv motor.
Quote:
ORIGINAL: extra 300
dionysusbacchus,
Best regards,
Old 02-13-2012, 04:10 AM
  #46
extra 300
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
[quote]ORIGINAL: dionysusbacchus
[quote]ORIGINAL: extra 300
dionysusbacchus,
Thanks for your reply. Just to make sure that i understood correctly. you meant to say i can use one 3S battery/fan-motor? What if i go with 4S per setup, will i still be ok?
On the other hand do you think that following ESC is of good quality to use on my application? :
TURNIGY TRUST 70A SBEC Brushless Speed Controller
Thanks again for your help
Regards,
Old 02-13-2012, 05:41 AM
  #47
dionysusbacchus
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I was talking about running the batteries in series. I'm not real familiar with twins, but I guess you could run one battery for each motor and have them completely separate. Like I said, on 6s my CS is right around 67amps and settles down to 60amps and 1495 watts. My Turnigy 80amp esc works great with this set up. The 2800kv motor will pull more amps than the 2100kv, and the 2800kv is only good up to 4s. So I would run two 3s packs in series with 2100kv motors, your plane has more than enough room for large packs.
Maybe someone with experience on your particular plane can chime in, you already spent $1500 on a kit, so I would get the 80amp ESC's.
Old 02-13-2012, 07:11 AM
  #48
gary41
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Regards,
If you use the 2800kv motors, run them on 4S. If you use one 4S LiPo, it should be at least 5000mAh/40C to power BOTH motors/you could use two 4S3300mAh/40C to power each motor separately, or wire them in parallel (4S6600mAh) to power both motors.
If you use the 2100kv motors, run them on 6S......you could use two 3S4000mAh/40C wired in series to make a 6S4000mAh supply.
I use Exceed-RC 80Amp OPTO ESC's, 4S5000/30-40C, 3100kv E-Flite inrunners (Delta V-15's) in my Windrider 737. Way more than enough power. I know its a bit smaller than yours.
Good luck!
gary41 is offline
Reply
Display Modes
