Smallest Servoless Digital Retracts -Looking for
I would like to convert a Nitroplanes 64mm EDFto servoless retracts. Iam looking for a setup that is less than 6oz in additional weight. The best Ican find are the 10-15 retracts from eflite and a semilar setup from hobbyking.
There must be a global manfacturer out there doing a true micro servoless retract system.
I appreciate at the feedback/help
David
RE: Smallest Servoless Digital Retracts -Looking for
Great! Thanks!
This is very helpful. Quick follow up question. This is a main gear servoless retract. Ilooked for a nose gear version on pw-rc.com but did not find anything. What do you do for a tricycle gear setup for the nose gear?
David
P.S. Ireally appreciate the help.
David
My Feedback: (13)
Nitroplanes.
For a nose gear, if you look at the construction of the mains, you can see that they can be made into a nose gear as well. That's what my CMP T-45 has.
Basically, a steel shaft that has a groove ground around it to have the set screw be screwed down far enough to hold in the steel shaft, but allow it to turn. Control arms are a standard collet with small threaded rods on each side to steer.
think about it.
Steve
think about it.
Steve
