6mm r/c jets
My Feedback: (110)
PA
6mm r/c jets
want to fly cheap and do aerobatics with a nice looking jet depron foam plane. there are several models. i just ordered the f-15 quick build. check out 6 mmrc.com...................RON
RE: 6mm r/c jets
Yeah they are a good little jet but i like the little edf jets that Hobbyking have putting out for a while now,i'll leave a link in case you might want to check them out,who knows you might like them too,for what you get the price is good too.
http://www.hobbyking.com/hobbyking/s...lug_n_Fly.html
http://www.hobbyking.com/hobbyking/s...arehouse_.html
http://www.rcuniverse.com/forum/m_11...m.htm#11116564
http://www.hobbyking.com/hobbyking/s...T-EDF_JET.html
My Feedback: (110)
PA
RE: 6mm r/c jets
this jet did not fly at all. went twenty feet into the air .......turned left and dove into the ground. already sold the crashed plane, motor ,esc and battery + servos. i'll stick to gas powered planes from now on, and my 27-q stryker that i like alot. the rest of the foam planes go know you know where..............RON
RE: 6mm r/c jets
I fly a 6mmflyrc QB F22. Very nice well built airplane and not any problems. It will do all I want and a lot more. I had an ESC go bad shortly after getting my plane in the air. They replaced it immediately. Great company!!
RE: 6mm r/c jets
Obviously there was something amiss with your plane. Sometimes it is a loose nut on the transmitter.(supposed to be humor) Did you have the correct CG or not enough power at hand launch? My F22 flies great, is powerful, fast and easy to hand launch and has never given a hint of the problem you describe. Even gas powered planes that aren't built right, set up right and flown incorrectly will crash just as quickly as your profile plane did. Don't see where sticking with gas power solves anything.
