New ARSON 153mm EDF For Byron jets
RE: New ARSON 153mm EDF For Byron jets
Mike:
Sorry, I don't have the plane handy right now. I did the conversion for a friend and the plane is at his house. Basically, the batteries were mounted in front of the fan and up against the top of the fuse. My friend and I made some battery mounting plates out of 1/8" lite ply. They were "stood off" (sic) from the fuse with some 1/4" square spruce so that we could wrap a Velcro strap around the tray and the batteries. The ESC was mounted in front of the battery trays with the motor leads routed along the side of the fuse and then thru the fan "firewall" to the back of the fan. Access to install/remove the batteries was thru the cheater hole in the bottom of the fuse. I will try to get some photos of the battery install shortly.
Ed
Ed
My Feedback: (45)
FL
Gents,
I want to thank Ed (edwarda10pilot ) for stepping up and answering some of the questions in the thread. I hope everyone is doing well and putting some good flying time at the fields. I just got home last night and wanted to send a quick update on the ARSON fan progress.
We are very excited about the new design concept. The design consists of 15 separate blades instead of the old 18 blades concept, however the new design will drop inside the Byron Original fan shroud without any modifications. Currently we have two prototype units that we will be sent to Ed Valls for performance evaluation. I trust Ed will give us a no nonsense performance evaluation of the Arson fan.
I've attached a few pics of the new impeller design
#33
My Feedback: (45)
FL
Ed,
Thank you again my friend. Bart to reiterate a bit more on your question the ARSON impeller is the same size as the original Byron and hurricane impeller. It was designed as a drop in replacement.
Cheers,
Joe
Cheers,
Joe
#37
My Feedback: (19)
I hope this comes to fruit one of these days!! Making mold for my Byro F-18 inlets ducting, got the tailpipe ducting from Iron Bay. Will order the Jet Legend stabilizer mounts with integral servo mounts in a couple weeks when I get another check. Plane is coming together, gonna need a fan!!!
Roger
Roger
#38
My Feedback: (45)
FL
Gentlemen,
A long overdue update on the preliminary test on the new ARSON Impeller. Please provide constructive criticism on the numbers being posted, . Ed (a10 pilot) has worked extremely hard to evaluate the impeller and we still have a lot of work ahead of us.
Disclaimer: If anyone post non productive comments and are trolling to get a reaction from other modelers don't bother posting because I will block you from the thread.
Test conducted by ED (A10 pilot)
ARSON MK 3 IMPELLER TEST
Byron Housing
Ambient temp is 44 degrees
MOTOR: Scorpion HK 5035-700Kv
CC 160 HV
12S Haiyin 5000 mAh 30-40C packs
Initial Startup:
Watts: 6555
Amps: 167.5
RPM: 16,626
Volts: 48.4
Stabilized (after about 30 seconds)
Watts: 6265
Amps: 167
RPM: 16,300
Volts: 37.4
Thrust: 17.5 lbs. (no inlet ring or tailpipe)
The tests run where logged data was at full throttle but only for about 30-45 seconds.
Will post the video shortly.
Ed if you would like to add additional information that I haven't posted please feel free to do so.
Cherie and I would like to wish each and everyone of you a very prosperous New Year.
Cheers,
Joe
Byron Housing
CC 160 HV
Initial Startup:
Watts: 6555
Amps: 167.5
RPM: 16,626
Volts: 48.4
Watts: 6265
Amps: 167
RPM: 16,300
Volts: 37.4
Cheers,
Joe
#39
Joe:
Thanks for posting the update.
All:
As Joe mentioned above this has been a labor of love and financed entirely by us (mostly Joe's money and a little of mine). We have been working on this for more than a year and progress has been slowed by funding, time to do drawings, some data crunching and finding the "right " machine shop that could/would help us and make parts that would fit our budget.
We are still working on the current draw and have some things in mind to lower the current but will wait to post the details until after we have a chance to test them on the bench. We have a test vehicle lined up and will do some testing when the weather gets a little better (warmer temps and lower winds). I did not post bench data but I have run this impeller up to 22K and it is absolutely smooth as can be. The impeller is designed such that the blades are removable/replaceable and are all "indexed" to a central hub. Our goal right now is to find the right KV for the impeller to try to get the best combination of current and performance. We have tried a couple of motors and the 500 KV seems to be the "right" one for the initial tests. When looking at the thrust, it may seem like it is not producing a lot of thrust in terms of the number of pounds of thrust but please remember that it puts out a TON of volume. The design of our setup allows me to change between the Arson impeller and the stock Byron 5 blade impeller by simply removing the impeller and replacing it with the next test article. This re-configurability will allow me to test fly the airplane with one impeller and then quickly change impellers and fly again. Additionally, we will have data logging as well as the eagle tree airspeed measurement system. We still have a ways to go so please be patient with us. More to come.
As Joe mentioned above, we welcome constructive input and will try to answer your questions.
Happy new year.
Ed
All:
Happy new year.
Ed
#41
JK:
Joe and I are making slow progress. I will provide some performance info below but it is still not quite what we were hoping for and we are in the process of looking at a few changes. As has been mentioned here before, this is a "part time" effort and dependent on available time. Work has been slow as the "day jobs" are getting in the way but we are making progress. We are moving very slowly over the past few months but we will get there.
Arson 15 blade impeller on 12S
Power: 8005 watts initially/7500 stabilized
Amps: 170 initially/156 stabilized
RPM: 13,500 max
Thrust: 19 lbs. 2 oz. initially/ 18 lbs. 12 oz. stabilized
Efflux: 233 mph (no intake ring or exhaust tube)
Arson 9 blade impeller on 12S
Power:6500 watts stabilized
Amps: 159 stabilized
RPM: 14,500 max
Thrust: 16 lbs. 14 oz. stabilized
Efflux: 204 mph (no intake ring or exhaust tube
The current is a little higher than we had hoped for so we are looking a little different blade design to reduce the current draw. We have designed this rotor/impeller to be reconfigurable so that you can configure the impeller as either a 9 blade, 11 blade or 15 blade impeller. I have run the impeller in the 15 and 9 blade configuration and the spacers work very well. Simply remove some blades, insert the spacers, bolt the unit back together and you have an impeller with a different blade count.
One of the other things I have been doing is to try to design a couple of universal brackets that will allow a person to use different types of motors to be used with this impeller or with a stock Byron impeller. I have designed a couple of brackets to allow different types and size motors to bolt to the stock Byron shroud and hope to have one of the prototypes on hand shortly.
So, here is where we are. The prototype unit is running on the bench with a 500KV out runner and it runs well but we are exceeding the rated current and power for the motor. We have another motor that is rated for higher power, current and volts and we will run it as soon as I get an adapter fabricated for the unit. I have made contact with another motor manufacturer and they will custom wind an inrunner for us is we want them to. We may try one of their motors. What we are trying to do is to offer the modeling community a selection of different fan configurations and an appropriate motor for each of the impeller configurations and it just takes time to find, buy and test these different motor combinations.
If we choose to go to production with this blade design then we need to fund the molding costs and this is rather expensive. If we decide to try a different blade design then we need to have the new blade machined and tested.
I know that our progress seems about as slow as a glacier moving but we are just some modelers/hobbyist that are doing this as time and money allow. Neither Joe or I have any illusions about this being a money making endeavor. I think we would be happy if we just got our investment back out of the pieces we sell.
Thanks again to all of those that have been following this thread and we hope you continue to follow us.
Ed
RPM: 13,500 max
RPM: 14,500 max
Ed
#42
I think you should make an inlet lip for it at least, so you can run it the same as most other fan testers do, will make for better comparisons to other fans and give you a better idea of g/w and its potential thrust. From memory my 127mm fan is pushing 15.4lb thrust without an inlet lip on 12s at just over 100A, with an inlet lip its pushing 17lb at 110A. As I dont do much testing without a lip I dont have data lying around you can compare with.
#44
Question, why does an inlet ring make that much difference? What about if you're using an inlet duct? Should you still use an inlet ring, and bring the duct up to the outside diameter of the ring? Thanks!
-Jorden
#46
Inside your model its a different scenario, as your inlet ducting creates the smooth flow path to the fan, you want the ducting as clean and neat as possible right up to the fan and you want the intake lip at the entrance to the duct or ducts, IE the intakes should be rounded to obtain a smooth flow into the ducting.
#47
I can see it has a mounting lip, but doesnt look like much of a curved inlet, hard to see in the photos though and never seen a byron housing over here. If its a square lip without a smooth radius then the fan will likely not be showing you its true thrust potential. But if that is a rounded inlet then the figures quoted are not very good.
#49
FL
I was checking back here hoping to see some progress. I guess the project lost steam....
You guys really did need to use a rounded intake lip. You are kicking yourself in the shins without. Might have seen more encouraging numbers.
#50
My Feedback: (45)
FL
John,
The project has been in a long hiatus, the performance of the prototype is encouraging. The last test runs we were getting an average of 21lbs at around 16k rpms, Research and Developing and testing a prototype is expensive and sometimes life tends to throw some curve balls and funds allocated for fun hobby projects have to be diverted.
I need to put the project back into priority and make time and build a Byron F-20 I have boxed in the garage, and test fly it.
Thanks again for the message.
Joe
Joe
