If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Results 1 to 2 of 2
  1. #1
    Join Date
    Aug 2009
    Springfield, OR
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Electric conversion
    I have a Bob Parkinson Regal Eagle F-15 Nitro Jet with the Byron fan and the Rossi .81 engine. I want to convert it to a twin electric EDF system. I plan on using two 90mm EDF electric fans. Will 3 KG per fan be engough, 3 kg will be about 6.6 pounds of thrust per fan on a six cell lipo if the specs are right. My jet weighs 11 pounds dry with no fuel with the nitro engine and Byron fan installed. I need to know if I should run a 8 cell fan with more thrust. I am just trying to keep the battery weight low.
    Specs:
    DESIGN TYPE. . . . . . . . . . . . . . . . F-15 SPORT JET
    POWER. . . . . . . . . . . . . . . . . . . DUCTED FAN
    ENGINE . . . . . . . . . . . . . . . . . . DUCTED FAN or OS .61FX
    LENGTH . . . . . . . . . . . . . . . . . . 68 IN.
    WING-SPAN. . . . . . . . . . . . . . . . . 53 IN.
    WING AREA. . . . . . . . . . . . . . . . . 613 SQ. IN.
    SWEPT AREA . . . . . . . . . . . . . . . . 1020 SQ. IN.
    WEIGHT . . . . . . . . . . . . . . . . . . 9-11.5 LBS.
  2. #2
    Join Date
    Jun 2002
    Langley, BC, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Electric conversion
    It would be a whole lot easier to run an E-Byrofan and 10 - 12 cells. Would turn out lighter too.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
