Change Sun 12 blade and Velocity Cool29?
CT
Asking you guys, especially the Extreme RC guys down south...bout a combo...
The 70 mm fan, Change Sun makes...with a Velocity inrunner and 6 cell or 5 cell....
What do you think?
Also, I've got 2500kv outrunners from Cyclone for a first trial
What do you think?
CT
RE: Change Sun 12 blade and Velocity Cool29?
Thanks...the picture there the Sabre you installed the 12 blade fan in? The sound's gotta be cool...
CT
Just Tested the Change Sun 12 Blade 70 mm Fan. With no Thrust Tube...but With Inlet Lip. Using the Cyclone CS480-2500-32 1400Watt motor.
5.12 Lbs. Thrust @ 1872 Watts @ 80 % Throttle.
6 Cell 65C Turning NanoTech Lipo, 3.3 AH.
At the 5.12 mark, my locktite gave in.
Gonna Try the Velocity Cool29...
CT
The Cyclone Motor was Quite Hot. Not Burnout Hot, just workin'''
I did not give time for the locktite to set. Still, gonna use the 1800 watt Cool29. 2.32 Kg is just shy of the 2.45 Kg. rating
