First EDF Jet
My Feedback: (19)
First EDF Jet
Hey guys, I am looking to get an EDF Jet. No t sure which is best suited for someone who is new to jets. I have been looking around and I see so many out there. So far I have been flying a fly zone senei and t-28 6 channel from banana hobby. Look forward to hear some good inputs from the experts!
ME
RE: First EDF Jet
I like the ParkZone Habu 2 EDF - foam, fixed gear, no flaps, 4S. You can add flaps, retracts, bump up to 5S (also bump up the ESC), etc., but it flies great, stock.
As your skills improve, you can add without breaking the bank.
Michael
Michael
ORIGINAL: soready04
CT
RE: First EDF Jet
Toysonics has the LX brand of 70mm foamies. The F-16 is a trainer to fly...easy to fly. the F-35 is easy too...and comes with electric retracts.
Upgrade the EDF to a wemotec minifan pro, or a ChangeSun 12 blade and Cyclone CS480-2500-40EDF outrunner and 5 cell Nanotech 65C pack. I've flown the F-35 and F-16 with stock fans, but I'm building a new one, with the CS12 70mm upgrade.
REsources:
Toysonics.com
RCCastle.com
Extremerc.com.au
Hobbyking.com
EJF.com
FanJetsUSA.com
PW-Rc.com
http://www.edfhobbies.com/
http://edfhobbies.com/index.php?rout...product_id=269
http://edfhobbies.com/index.php?rout...product_id=128
http://edfhobbies.com/index.php?rout...product_id=201
Here is my configuration for the F-35 power system...
Speed Controller: http://www.hobbyking.com/hobbyking/s...a_Logging.html
Motor: http://www.hobbyking.com/hobbyking/s...ion_29mm_.html
Fan Unit: http://edfhobbies.com/index.php?rout...product_id=269
Battery: http://www.hobbyking.com/hobbyking/s...Lipo_Pack.html
If you've never assembled an EDF unit...get the motor at EDFHobbies..and let them assemble and balance your unit. use the 6 cell motor from them...2200kv
The F-35 has vector thrust nozzle, which you can skip by leaving off the servos and gluing the nozzle in, the vectoring requires a rudder and elevator mix, and may be too complex/ And has 2 rudder, 1 steering, 2 aileron, and 2 elevator servos. I use the BEC in the speed controller, but the retracts draw power, so separately power them, or use a separate BEC 6 cell to 6 volt 5 amp. Here>http://www.hobbyking.com/hobbyking/s...for_Lipo_.html
REsources:
Toysonics.com
RCCastle.com
Extremerc.com.au
Hobbyking.com
EJF.com
FanJetsUSA.com
PW-Rc.com
RE: First EDF Jet
ORIGINAL: soready04
This one is a great performer, flies truly good. Probably the best of the small EPO EDFs
http://hobbyking.com/hobbyking/store..._EPO_PNF_.html
I also like the concept of the Zephyr, alot of wing and probably a nice one too.
http://hobbyking.com/hobbyking/store...33mm_PNF_.html
RE: First EDF Jet
My first EDF was the Banana Hobby Starmax 64mm F-18. It is more fun than I can tell you!
Here is my first flight:http://youtu.be/y7LdUz6U0fQ
Here is my latest recorded flight with it: http://youtu.be/EseHS8bPaUA
A crash that is survived and flew immediately after:http://youtu.be/2qxcV0M4PCE
There may be better options out there, but this one worked out extremely well for me. $109 and a wealth of experience and lessons learned from flying it.
GB
GB
MN
RE: First EDF Jet
If you want first jet it shouldbe a simple and slow speed jet.I also choose F16 Starmax 64 mm EDF jet for mysmall brother.It is really large scale model so that it not only looks great,but also very stable in the air. If you are not ready to fly at highspeeds or complex 3D stunts, you can also fly the plane very slowly.<o></o>
