Electric RC Jets Discuss rc electric ducted fan or radio control prop jets here.
Boeing 777-200 LR 1:44 scale (B7 project)
Reply
Old 10-12-2013, 03:19 PM
leadatinbox
leadatinbox's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default 12 / 10 Frame
Today I was producing the frame.
Early concept of inner structure is shown here. It's made of aluminium tube and carbon stripes.
very detailed photoset
This part is an engine support, it will be made of aluminum corner
4 hours and more then 30 cut-off discs later
weight is the same as in the 3D drawing
leadatinbox is offline
Old 10-26-2013, 03:06 AM
leadatinbox
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Aluminium
Today I'd like to talk about the mechanization of my aircraft. Here is a small list for a wing:
  1. inboard flap
  2. outboard flap
  3. inboard slat
  4. outboard slat
  5. aileron
  6. spoilers (both)
total of seven moving parts, or, as it's said, ! I'll go in order
First of all, I have chosen a certain plane in the wing with a 7-degree angle to the horizon. This is going to be a layout for all moving parts.
1. Inboard flap
Since I have hollow wings, I decided to implement the construction of the flap by this way
As the bearings I'm going to use brass tubes 3x1.5mm and steel rod with 1.4mm diameter.
Video of the final result
http://vimeo.com/46074754 2. Outboard flap
Outboard flaps are implemented in a similar way
http://vimeo.com/46205474 3. Inboard slat
http://vimeo.com/46258998 4. Outboard slat
http://vimeo.com/46261076 5. Aileron
My basic idea to hide everything inside the wing in this place delivered me the most difficulties. And, if for other elements I am calm, there is still a very large field for r&d.
6. Spoiler
It's simple - no additional mechanisms, one side is fixed, and other will be connected to the servo arm. I saw it somewhere on rcgroups - very simple and easy.
And that's just all in one wing, but there is a tail section
http://vimeo.com/46397445
http://vimeo.com/46460474 and gears
http://vimeo.com/47149996
http://vimeo.com/46473860 All of this was designed, thought out, calculated. Left to do
In fact the entire frame is made so all items could be cut out of the three basic shapes - square tube 20x20x1, 20x20x1 corner and flat aluminum 1 mm thick. I've tried to make a part of frame - I've spent whole day and not satisfied with the results, but the concept is tested and approved
After that, I've realized that I have to place an order for cutting. Calculations gave me the length of cut over 400m And once again I have to find way to make it
ID:	1933116   Click image for larger version
ID:	1933117   Click image for larger version
ID:	1933118   Click image for larger version
ID:	1933119   Click image for larger version
ID:	1933120   Click image for larger version
ID:	1933121   Click image for larger version
ID:	1933122   Click image for larger version
ID:	1933124   Click image for larger version
ID:	1933125   Click image for larger version
ID:	1933126   Click image for larger version
ID:	1933127   Click image for larger version
ID:	1933128   Click image for larger version
ID:	1933129   Click image for larger version
ID:	1933130   Click image for larger version
ID:	1933132   Click image for larger version
ID:	1933133   Click image for larger version
ID:	1933134   Click image for larger version
ID:	1933135   Click image for larger version
ID:	1933136   Click image for larger version
ID:	1933137   Click image for larger version
ID:	1933138   Click image for larger version
Old 10-26-2013, 06:43 PM
leadatinbox
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default PETG cutting
I faced with the problem of the plastic correct cutting - I need experienced advice
The basic principle is as follows - moulds were made with the additional 5mm. Then I need some kind of bar with 4mm height with thin blade mounted on the top.
Theory in pictures
Here is the needed detail. Offhand, it consists of two halves - top and bottom.
Moulds will looks like this
Additional forms part for a sacrificial plastic
cutting process will looks something like this
special tool
and a scheme
And here is a reality
Half of the fuselage - why I did a additional step I do not remember, it was 1.5 years ago
I picked up a pack of baby food and make a brick about 4 mm height
I try to cut and here I have difficulty - so I need an advice
In short - everything goes not according to plan
And how would you cut this plastic?
ID:	1933402   Click image for larger version
ID:	1933403   Click image for larger version
ID:	1933404   Click image for larger version
ID:	1933405   Click image for larger version
ID:	1933406   Click image for larger version
ID:	1933407   Click image for larger version
ID:	1933408   Click image for larger version
ID:	1933410   Click image for larger version
ID:	1933411   Click image for larger version
Old 11-15-2013, 10:12 PM
leadatinbox
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Project update
I'll come up for a moment from the world of outsourcing to explain what has been done on the frame.
All frame's parts are conventionally grouped by manufacturing technology and layout angle: +7, +8 and zero.
tube 20x20
already done and is coming to me - the material aluminum 6063.
Laser cutting of flat aluminum
Material - Aluminum 6061-T6, I found the service provider and will get it soon
CNC aluminum machining
used to conjugate planes +7 and zero, already been done and is coming to me - the material aluminum 6063-T5.
carbon fiber strips and rods
five minutes from order
mounting corners
so hard to find supplier, I'm still looking
bearings
Basically found. The outer diameter of 3 mm, 1 mm bore size. Some of them are made ​​of plastic.
styrofoam
Everything I need for cutting tool is bought. I'm waiting the cut templates.
fasteners
M3 and a little bit of M2 is used for frame mounting, so I had to order them
chassis
There still needs to work - here will be used cnc and cutting, rubber and plastic molding, bearing, two kind of springs, M2 fasteners and ...brakes. As always - with blackjack and ...
Who knows, maybe somewhen h-king will sell chassis from SSAir
ID:	1939635   Click image for larger version
ID:	1939636   Click image for larger version
ID:	1939637   Click image for larger version
ID:	1939638   Click image for larger version
ID:	1939639   Click image for larger version
ID:	1939640   Click image for larger version
ID:	1939641   Click image for larger version
ID:	1939643   Click image for larger version
ID:	1939644   Click image for larger version
ID:	1939645   Click image for larger version
ID:	1939646   Click image for larger version
ID:	1939647   Click image for larger version
ID:	1939648   Click image for larger version
ID:	1939649   Click image for larger version
Old 11-16-2013, 09:50 AM
SkidMan
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Amazing!
Thank you for sharing your progress. I will be following you.
Paul
SkidMan is offline
Old 11-30-2013, 10:18 PM
  #31
leadatinbox
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default 12 / 01 Frame progress
Quote:
Originally Posted by SkidMan View Post
Amazing!
Paul
Thank you, Sir!
First results of producing frame components.
This is main frame's structures - aluminium tube with cut out holes, weight 198 grams.
This items are used to conjugate inner aircraft planes +7 and zero, weight 34 grams.
Also I got my dsr retracts - dsr 46, frame of my aircraft was especially designed for this system, weight 173 grams.
Seems, my callsign will be "too heavy 777"
Laser cutted details are still to come, I have only process's and quality control's photos
While I was looking for wheels for my chassis I've decided to do it by myself. All wheels with outer diameter about 35mm that are on market or too ugly or too expensive for me. As always I'd like to make my wheels with blackjack and ... - two stamped metal rims, two decorative caps, natural rubber hollow tire, insets for axles with two different diameter, nice M1 fasteners
and all this for ... - yum yum .
Slightly heavy - about 10 grams per assembled wheel (7 grams only for tire), but I'm sure to be satisfied with overall look and quality.
someone wants scaled good-looking wheels?
ID:	1943852   Click image for larger version
ID:	1943853   Click image for larger version
ID:	1943854   Click image for larger version
ID:	1943855   Click image for larger version
ID:	1943856   Click image for larger version
ID:	1943857   Click image for larger version
ID:	1943858   Click image for larger version
ID:	1943860   Click image for larger version
ID:	1943861   Click image for larger version
ID:	1943862   Click image for larger version
ID:	1943863   Click image for larger version
ID:	1943864   Click image for larger version
ID:	1943865   Click image for larger version
Old 12-14-2013, 05:32 PM
  #32
leadatinbox
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default 15 / 12 Two steps forward - one step back
Two years ago when I was designing airfarme I choosed DSR as retracts for my plane. I hadn’t this at hands while was designing so drawings were taken from their site.
On this week I got my laser cutted items and here is the result.
There are two general types of DSR - 30 and 46. In all of my drawings title 46 participates. but…
It seems that I used 30's drawings instead of 46's, so those parts should be remade.
Wheel 35x13mm
My wheel consists of nine parts.
Today fourth part turn has come. Week ago it looked like this
and today .. ta-da
Next will be M1 fasteners (pos. #5 and #6). They have been bought already and are coming to me.
One more parcel has arrived - micro bearings with outer diameter three mm.
I'm still thinking about main gears axles - may I use 1mm axles with bearings or it won't be enough to carry load?
ID:	1947549   Click image for larger version
ID:	1947550   Click image for larger version
ID:	1947551   Click image for larger version
ID:	1947552   Click image for larger version
ID:	1947553   Click image for larger version
ID:	1947554   Click image for larger version
ID:	1947555   Click image for larger version
ID:	1947557   Click image for larger version
ID:	1947558   Click image for larger version
ID:	1947559   Click image for larger version
ID:	1947560   Click image for larger version
ID:	1947561   Click image for larger version
ID:	1947562   Click image for larger version
Old 12-14-2013, 11:51 PM
  #33
leadatinbox
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I've tried to assemble laser cutted parts and realized that instruction has to be done
rough weight is about 160g
+ tubes 170g
+ 4m of carbon fibers strips 280g
and, airframe weight is about 610g
ID:	1947617   Click image for larger version
ID:	1947618   Click image for larger version
Old 12-29-2013, 03:26 PM
  #34
leadatinbox
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default 30 / 12 Reverse concept
I'm haunted by edf reverse idea for my CS90
What do you think - is it worth it?
All parts are made of 0.15-0.3mm steel, control rods are 1-1.4mm diameter, fasteners M2, overall weight will be about 50g per engine.
any thoughts?
ID:	1952354   Click image for larger version
ID:	1952355   Click image for larger version
ID:	1952356   Click image for larger version
ID:	1952357   Click image for larger version
ID:	1952358   Click image for larger version
Old 01-01-2014, 02:47 AM
  #35
leadatinbox
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default 01 / 01 New Year update
Happy New Year! I wish you health and prosperity in the New Year!
Let the New Year will be for us full of joyful events and pleasant moments, and failures and non-flying weather bypasses aside!
Tires for my wheel will be made by two stage. First stage is the simplified prototype. And I got it just before New Year
One of it was cut to see the profile
It is slightly heavier than it was planned - about 6.5g / unit
Also I got my m1 fasteners for wheels
By the way, here is another prototype
What do you think about the purpose of this thing?
ID:	1953054   Click image for larger version
ID:	1953055   Click image for larger version
ID:	1953056   Click image for larger version
ID:	1953057   Click image for larger version
ID:	1953058   Click image for larger version
ID:	1953059   Click image for larger version
ID:	1953060   Click image for larger version
ID:	1953062   Click image for larger version
ID:	1953063   Click image for larger version
ID:	1953064   Click image for larger version
Old 01-02-2014, 07:48 PM
  #36
leadatinbox
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default I'm afraid of this thing
ruler is only 46 cm length
ID:	1953593   Click image for larger version
ID:	1953594   Click image for larger version
Old 01-18-2014, 11:32 PM
  #37
leadatinbox
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default 01 / 19 The last piece of puzzle
Ok, I'm almost ready to assemble my airframe
Today I'll try to prepare my corners. Couple of months ago I've placed order for it. I need a lot of various corners for my airframe and I can't think of anything better than this method for producing - to lay out all of it on four sides of tube for laser cut. But cutting should left a little bit of space on edges. This will let to make delivery and producing of whole frame more cheap and simple. Chosen method looks like this.
tube isn't very big - 20 x 20 wall thickness 1 mm, length about 60cm
I used this tools but one simple hacksaw is enough for it. At first I freed engine's levers
then everything else
half an hour of work and everything is done
For better look it has to be polished because laser cutting leaves behind small droplets of molten aluminum on the inside surface of the pipe. You may see it on left picture.
After an hour everything is ready for further assembling, corners overall weight is 54g
ID:	1959342   Click image for larger version
ID:	1959343   Click image for larger version
ID:	1959344   Click image for larger version
ID:	1959345   Click image for larger version
ID:	1959346   Click image for larger version
ID:	1959347   Click image for larger version
ID:	1959348   Click image for larger version
ID:	1959350   Click image for larger version
ID:	1959351   Click image for larger version
ID:	1959352   Click image for larger version
ID:	1959353   Click image for larger version
Old 01-20-2014, 04:32 AM
  #38
leadatinbox
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default It's Alive!!!
http://www.youtube.com/watch?v=xos2MnVxe-c
B7 frame consists of five groups
flat aluminum details and cnc machined aluminum connectors
specially made wing mechanization items and a little bit of fasteners
aluminium tubes with corners and carbon fiber products
Everything except special M3 fasteners is ready, it's time to make an assembly
At first I've tried to use a stopwatch to determine right time but then I gave up on this idea
Here you can see how my +7 connectors are used
two with a half hours and wing section is assembled
Intermediate weight is 340g (17g is weight of drill bits)
Plus ninety minutes and central part is made also. Its weight 270g
overview
Angles should be +7 on the wing and +8 on the stabilizer
While assembling I've found several details to improve, for example - my logo is made head over heels
ID:	1959837   Click image for larger version
ID:	1959838   Click image for larger version
ID:	1959839   Click image for larger version
ID:	1959840   Click image for larger version
ID:	1959841   Click image for larger version
ID:	1959842   Click image for larger version
ID:	1959843   Click image for larger version
ID:	1959845   Click image for larger version
ID:	1959846   Click image for larger version
ID:	1959847   Click image for larger version
ID:	1959848   Click image for larger version
ID:	1959850   Click image for larger version
ID:	1959851   Click image for larger version
ID:	1959852   Click image for larger version
ID:	1959854   Click image for larger version
ID:	1959855   Click image for larger version
ID:	1959856   Click image for larger version
ID:	1959857   Click image for larger version
Old 01-27-2014, 04:54 AM
  #39
leadatinbox
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default giveaway
life is such a wonderful thing that you never know where you can find and where you lose
Looks like it's time to finish my B7 project and everything connected to it. In connection with this I announce giveaway of B7 components
shells
and airframe components
all for free, if somebody is interested, please, send me a message
ID:	1962448   Click image for larger version
ID:	1962449   Click image for larger version
Old 02-20-2014, 02:30 PM
  #40
leadatinbox
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Sayonara, B7!
for last three weeks all of ten B7 complects were given in good hands throughout Russia.
I've used 57 square meters of carton and tons of adhesive tape
Overall weight of the goods delivered is more than 200 lbs
Last four were sent yesterday in this big box
For today I can say "Sayonara, B7 1:44"!
ID:	1970624   Click image for larger version
ID:	1970625   Click image for larger version
ID:	1970626   Click image for larger version
ID:	1970627   Click image for larger version
Reply
Display Modes
