Need Fast Start on HK ESC
Hi,
I have a problem with my LX F16 70mm EDF with Vector. I did a couple of Mods.
Mod 1: Added two more servos to have AILERONS instead of ELEVONS
Mod 2: Got rid of the mixes (Elevon) so I have separate AILERON and ELEVATOR.
Mod 3: Added a new Dr Mad Thrust 12 blade 70mm EDF
Mod 4: Added a nes Red Brick HK 100A ESC
Looks like everything is working ok, but when I made a test run I did not get any lift at full throttle. When I got the plane back and I accelerated there was a delay to get to full power. I assume this ESC had a Heli Soft Start, at least this is what I felt, and so the other guys that were with me.
When I looked at the ESC Programming Card (attached) the options for start are : Very Soft, Soft and Start-ACC (which I do not know what it means, but I assume active start). I programmed the ESC as attached but I do not see any difference between them. The start is way soft...
Attached are the ESC and the programming card with my settings.
