What to do, Ultrafly F-16
Does anybody know what I have to do to make my F-16 working? When I turn the reciever on, the servos are turning like crazy and the engine doesn't start when I give gas...???
Anybody knows this problem? I have the Ultrafly kit including the brushless engine...
Eric
Eric
RE: What to do, Ultrafly F-16
check the routing on your reciver wire first. Make sure its not running right over the power wires.
Also make sure that the battery Plane and transmiter is fully charged.
If you have a second reciver try swapping the current one out
TN
Be sure you have your TX turned on. As that is what happens when the Rx doesn't get a signal from the Tx. Check your Antennas. If you have a spare rx, test your servos and motor on it.
Just a pet peeve of mine, so take no offense to this, but I prefer "motor" not engine. And electrics don't use "gas". You give it more "throttle" not give it more "gas". Just a pet peeve of mine, don't be offended, I say that to everybody.
