WE MO TEC 620
FL
WE MO TEC 620
Howdy
I need to know what motor to use with the WeMoTec 620 EDF unit. Fan is 85mm diam.
I'd like to use no more than 4S LiPo (6ah) , and I have a Phoenix 80 esc. This combo with a Hacker B 50 8L drew 110 amps . Temptation was to get a larger speed controller (the thrust was awesome), but I knew the motor was not rated for such abuse.
The aircraft is a scratch-built F-104 about the size of Stumaxx's, and weighed 3.5 lbs and cruised around 160mph on theKressfan/K&B.21 . The WeMoTec unit dropped right in like I had built the plane around it, so I'm really anxious to get it up again. Anybody have any idea what motor to use?
Jaffray
Jaffray
AZ
RE: WE MO TEC 620
Hello Jaffray,
Unfortunately 4S is not going to do it as you found yourself. The HW-620 and HW-609 are trimmed down Midi Fan rotor's and stator assemblies with a carbon fiber housing attached so the loading is very similar and so are the power setups. Here is a couple of motor combos in the 900 to 1200+ Watts
Hacker B50-15L (6S - 7S) , B50-11XL (7S - 8S+)
Mega 22/30/2 (6S - 7S), Mega 22/30/3 (7S - 8S+)
--RW
--RW
OH
RE: WE MO TEC 620
Jaffray,
The Wemotec 620 is a cut back version of the Midifan with a higher eflux. Like most midi sized fans, it requires a 500 sized motor as you noted and when you get into these sized setups, you are going to have to use a 5S or 6S minimum to get good, usable power. A B50-13L or 15L would be a better choice and keep you in a good power range without going overcurrent on the motor.
Carl
Carl
