Ultrafly F-16 HELP!!
WI
If anyone is or has been through the build process with the Ultrafly F-16 please help answer this question! I am on page four and things dont fit together. I have the 320 mm pushrod cut to size but it wont fit in the aluminum elevator controll hole. What do I do?
RE: Ultrafly F-16 HELP!!
Hey Guy,
Are we having fun yet.? To answer you questions,Go to page 9 take a look at #3 pic. that should help.Sometimes
with this kit you have to advance to further pages to undersand what they want done...As far as the canapy goes
the end of the canopy ( the front end) should hang over the end of the foam piece 11/16.....So it covers the exsturding
foam on the front of the fuselage assembly.........That is also has to be covered by the canopy........
If you have any questions, just Yell.....
WI
Ok but my canopy isn't even cut to a point on the back end like it shows and thats why it won't make contact with the foam. I completely understand that the canopy needs to overhang a little on the front though.
WI
Ok I have diagnosed the problem, Ultrafly sent me the wrong canopy. I got the one for the SU-27 no doubt so im sending a message to Ultrafly and hopefully they will send me one ASAP!!!![:@]
i got one had problems with it would not fly at all
nose dived every time
CHECK THE FINAL WEIGHT NEEDS TOBE 590GRAMS AS NEAR AS POSSIBLE THEN WOW IT GOES LIKE STINK
