Bobcat 50 edf coversion
Hello,
I have a Bobcat 50 inch span arf that i want to try with edf,any one tried yet? i hope to use an Airpower 120 mm fan with a matching neu brushless motor,any hints etc welcome,
thanks in advance Euan.
RE: Bobcat 50 edf coversion
Hello,
I,ve done a bit more on my Bobcat project,i have installed an Aveox 36 series motor with a kv of1950,i ran the motor up in a Wemotec 90mm fan on 6s and got 1650 watts @ 71 amps will this be enough my estimated all up weight is 6lbs.
For a comparison my friend flys the same model on 850watts but using a pusher setup ,
any input welcome .
cheers Euan.
any input welcome .
cheers Euan.
