Electric RC Jets Discuss rc electric ducted fan or radio control prop jets here.
FUNJET
Reply
Old 12-02-2010, 07:26 PM
  #1151
Gryphon
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: FUNJET
chippedprop,
Sorry to hear that my friend....Looks like you have had much better luck with Strykers.
If there is anything I can help with let me know.
PM me if you want to try a new in a box MEGA 16/25/2.5RC 5mm shaft.
{Roughly 2300KV and you can run it at 80A in Funjet (6S max), higher AMPs in a Stryker (5S max) }
Gryphon
Gryphon is offline
Old 12-13-2010, 01:29 PM
  #1152
alekshauge
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: FUNJET
Hi!
Never posted any here before
I had read the hole tread last year, before I desired to go for a Mega 16/25/2. It has been a great experience!!! I reached147mph this weekend, wih a graupner 6,5x6,5 and just over 1260 watt. The new nano batteries from hobbycity is great! I use a 4cell 2200mah 75c burst. The measerment is from a hobbycity device, and only read the highest numbers.lol, so this is in a dive, ore at the end of one..lol
With this inspiration I desire to read whats new since last year. been reading this all night now, and found out that some are running this Mega 16/25/2on a 5cell!!!! In my dokuments that came with the engine, it says max 16volt. In the post of Three Four Left, his dokuments nowsays 20volt.. Hmm dont understand this maybe a diiferent type..says something about rotor? on the first link.
http://images.rcuniverse.com/forum/u...12/Av68497.pdf
http://www.puffinmodels.com/product.php?prod=809
Anyway, I`m planning on a new funjet with fibercloth, and a good setup. Thats way I need to now if the Mega setup will last on a 5cell? anyone flown it on 5cell for a longer period, andon what propeller?I use a CC80amp Esc with 120amp amp burst and aseperate CC.bec.
Hoping to reach about 155 - 160mph with the new one.
Very good tread this
Thanks.
Aleks
ID:	1533793   Click image for larger version
alekshauge is offline
Old 12-13-2010, 02:04 PM
  #1153
Extreme_RC
Extreme_RC's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: FUNJET
Here is some video of our new power system as run by Psionic in NSW. Running an ARC3655 inrunner on 6 cells with some wicked shaped apc scimitar style 7" props.
[youtube]http://www.youtube.com/watch?v=26B39689ct8&feature=player_embedded[/youtube]
Extreme_RC is offline
Old 12-13-2010, 03:18 PM
  #1154
Dad_Roman
Dad_Roman's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: FUNJET
ORIGINAL: Extreme_RC
Here is some video of our new power system as run by Psionic in NSW. Running an ARC3655 inrunner on 6 cells with some wicked shaped apc scimitar style 7'' props.
Awesome speed! I dont doubt those figures and what you guys downunder are accomplishing is amazing! Hats off to you!
.....if I may point out.
Your radar guy seems to get extremely excited. I noticed this in the other vid(s) also.
When taking a radar reading or a doppler reading the measuring device needs to be stationary. Not waving around as if filming.
You ever watch the cops with hand held radar? They hold it with both hands and very very still and allow the target to pass through!
Just my humble opinion
Dad_Roman is offline
Old 12-13-2010, 05:14 PM
  #1155
Extreme_RC
Extreme_RC's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: FUNJET
Not my video or my state so no way to control how its used With that said you would get a better higher reading by staying still, trying to follow the model as it passes will only reduce your reading I would think. I have held a gun and the speed come up before the model gets to you, so it really wouldnt matter about him moving, he will still have a peak reading before he moved.
He is also standing at an angle to the model which will lower the readings, I found this out when first holding a radar gun for some guys at the field.
Old 12-14-2010, 01:08 PM
  #1156
alekshauge
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: FUNJET
Hi RCfriends!
I have been looking at the Mega 16/35/1,5R http://www.megamotor.cz/v3/script/de...ge_id=lang_engand wonder how many amps a 5cell lipoaround 2600mah 90c burst, with a 6x6 graupner prop on will make. I have a cc 125 amp ESC with 160 burst, but also a cc 80amp ESC with a 120 burst, and wonder if I should go heavy ore light. Any suggestion? Ore should I just stick with the 16/25/2 and run that on 5cell. It has almost the same kv, but could it take 5cell in the long run?
Thanks!
A
Old 12-21-2010, 10:48 PM
  #1157
Gryphon
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: FUNJET
alekshauge,
Go with Phoenix 125A ESC. That question was the easy part. Use that ESC for the 1.5S or 1.5R motor
6X6 and 5S will be a problem for the (2) motors that you mentioned due to their KV.
Without me checking the data; you will probably be better off with 16/40/1.5S or 16/40/1.5R both have lower KVs than 16/35/1.5R , and ofcourse 16/35/1.5S (2200KV)
I suggest you ask your question on the Stryker thread....tell them that you have a Funjet with limited cooling airflow as compared to what they are used to in a Stryker.
We might just run a test for you and give you actual data.
***Would be good to comment on max AMPs that you want to draw from your battery.
So when you comment on your desire to run 6X6 they can better help you with proper KV MEGA motor.
Also give serious thought to the 5mm "COMBAT" shaft, so that it will not bend during landings....(no extra charge)...use letter "C" such as 16/35/1.5RC
Make sure to comment on your flying style as far as max burst speed runs followed by long periods of cooling glides or if that you will stay on the throttle for longer periods of time.
USE MPI style full size heat sink and ask for links as needed:
http://www.rcuniverse.com/forum/m_10...20/key_/tm.htm
Gryphon
Gryphon is offline
Old 12-22-2010, 01:12 PM
  #1158
alekshauge
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: FUNJET
Gryphon.. thanks for youre reply!
I dont need to go for a 6x6 prop, I just want a faster plane than the one I have now. Dont need to set a record if you now what I mean
What would you put in a coated funjet now days, without going to heavy? 4cell ore 5cell, but not too big battery, maybe around 3000mah lipo. Ore maybe 6cell ( 2x3cell 2200 mah ) dont now. Ouch here we go again..lol
For cooling I have scarved another hole behind the one that are in the plane out of the box. This seems to work ok. Direct airflow in too the engine, just streaming over the Esc.
I am going for a MEGA and a CC Esc. Just need to find the right combo
Thanks!
A
Old 02-02-2011, 08:29 AM
  #1159
hoelshot
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: FUNJET
I was curious if this motor would be a good fit for the Funjet?
[link]http://www.atlantahobby.com/Store/pc/Neu-1110-2Y-3-2mm-shaft-465p6566.htm[/link]
hoelshot is offline
Old 02-02-2011, 09:42 AM
  #1160
tIANci
tIANci's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: FUNJET
Hoel ... if you got the money, why not?
tIANci is offline
Old 02-11-2011, 12:33 PM
  #1161
Gryphon
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: FUNJET
hoelshot,
MEGA 16/25/2C with 5mm shaft will have every single advantage that you can think of. $110-$114 ( 5-6 Weeks wait )
Higher capability as you go down the list. +5mm and extra 20 grams per each step.
16/30/1.5SCE
16/35/1.5RCE
Gryphon
Gryphon is offline
Old 02-12-2011, 01:02 AM
  #1162
tIANci
tIANci's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: FUNJET
Gryphon ... now that we have 45C batts and I bought 6 pieces of the 3S 2250s, I think I shall put my HET 2W/25 to good use! Bought the Ultra and I think will start to work on her soon. You think she will be ok with a mere HS65? Also am trying to finish off my original FJ with a Mega 16/15/3 tonight. That will be so sweet to fly as I keep her light, maybe on 3S 1500s
tIANci is offline
Old 02-14-2011, 07:36 AM
  #1163
tIANci
tIANci's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: FUNJET
Here she is ... original Fun Jet No. 6 I think ... Mega 16/15/3 ... APC 5x5 ... DualSky 40A ESC ... x2 HS65 ... DualSky 45C 3S 2,250. I love the sinister look. Yeah!
tIANci is offline
Old 05-17-2011, 11:50 AM
  #1164
moparmyway
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: FUNJET
ORIGINAL: alekshauge
I am going for a MEGA and a CC Esc. Just need to find the right combo[img][/img]
Thanks!
A
I would humbly suggest thinking about the following setup.
MEGA 16-35-2
Phoenix 125 (I used an ICE 100)
6s2650 (45/90)
APC 6x4 Sport, Graupner 5.5x5.5, and up through APC 6.5x5 or APC 6.5x6
Here is a video of the setup on an APC E 6x5.5
http://www.youtube.com/watch?v=Kec66ZQdPyA
Here is the setup on a Graupner 5.5x5.5
http://www.youtube.com/watch?v=VfUORpkTcCY
Here is the setup on APC 6x4 Sport
http://www.youtube.com/watch?v=ttA02...eature=related
moparmyway is offline
Old 05-17-2011, 12:46 PM
  #1165
alekshauge
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: FUNJET
Hi!
Thanks for the reply Moparmyway.
That look like a good setup you have there. I really like youre handlauching too... really cool....
I Went with the MEGA16/25/1,5sc. Havent finished the plane yet, been lots of other things to do lately. Ihave fibercoated the hole plane, and put Robart hinges in the wings. Hope that will prevent what you show in youre youtube video... My F16 had its wing ripped of in the middle of the air, so I have learned the hard way, that we need some strength to keep them together.
Must say that the fibercoating made the plane really stiff, and were amazed of that. Also thatit doesnt feel so heavy that I was afraid off.
Think I will go for 2650 ore 3000 mah 4cell nano in it aswell,
Thanks.
A
Old 05-17-2011, 04:47 PM
  #1166
moparmyway
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: FUNJET
OK, here is your 16-25-1.5sc with a 4s battery and a Graupner 5.5x5.5
Old 05-18-2011, 06:04 PM
  #1167
apache
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: FUNJET
Im looking for esc and motor set up for a funjet under $100. cheapest way to get more speed with 3s lipo
I found the funjet at grayson hobby with motor and 50amp esc for only $112. multiplex wanted $140 just for the power pack. am I missing something with such a great deal?
apache is offline
Old 06-25-2011, 07:01 PM
  #1168
tom_sandiego
tom_sandiego's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: FUNJET
I don't know how you guy control the funjet with that speed 180 plus my funjet just a little over 100 that made me nervous every time i fly.
tom_sandiego is offline
Old 06-27-2011, 02:56 AM
  #1169
tIANci
tIANci's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: FUNJET
Tom ... the more you fly her, the more you will get used to it. Soon you will say 100 mph is boooooring
Apache ... its not worth pushing a 3S set up too hard. Want speed? You need VOLTS. Simple as that ... using a 3S for speed means high amps, you can potentially overwork your batteries.
tIANci is offline
Old 06-30-2011, 11:59 PM
  #1170
Cliffhanger
Cliffhanger's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: FUNJET
Here's a pic of my funjet.
it is not that fast but it sure is LOUD !!
Cliffhanger is offline
Old 07-29-2011, 12:51 PM
  #1171
snatch-it
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: FUNJET
hi guys
been reading through quite a few pages on this thread!!!!!
just finished building the funjet ultra and flown it on 3 cells with a 3600kv cheap chinese motor. flys well, but not fast enough!!!!!!!!!
i have another set up for it,,,,,,, motor is a HET 2w 25. 2200 6 cell lipo of 60c discharge constant, 120amp controller and a apc 5x5 prop.
how and what do you guys think of this set up??????
thanks in advance
nigel
snatch-it is offline
Old 07-31-2011, 02:13 AM
  #1172
SycoSim
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: FUNJET
I think this is going to be a good reasonable setup for a 'Fast Quick Run'
We took it out last night and it was really shifting.. need a speed gun now : -)
For a 28mm motor it sure packs some punch! on 6 cells.. It come down and it was only slightly warm.
Sy
SycoSim is offline
Old 07-31-2011, 07:04 AM
  #1173
tIANci
tIANci's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: FUNJET
Nigel ... you will pull too many amps with the 5x5 ... try a 4.75x4.75 for starter ...
tIANci is offline
Old 07-31-2011, 09:40 AM
  #1174
snatch-it
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: FUNJET
no probs, will do, bought a couple of 4.75x4.75"s.
wont get chance to try them now till next weekend.
thanks for the info. any more info is always welcomed!!!!
nigel
Old 07-31-2011, 06:05 PM
  #1175
tIANci
tIANci's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: FUNJET
Nigel ... let us know how she goes, I was about to do the same as you, as I have a 2W-25 ... all the best.
tIANci is offline
