Electric RC Jets Discuss rc electric ducted fan or radio control prop jets here.
Nitro Planes A-10 Warthog for 95 dollars
Reply
Old 05-05-2010, 06:29 PM
  #976
CochiseSignal8
CochiseSignal8's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Nitro Planes A-10 Warthog for 95 dollars
Hope you're able to get your plane back from the swamp, Cordwood. At least you got some flying time on it! When i do get outside, im having to avoid all the cactus growing here. Man, those things are rough on a foamie! Still on a quest to upgrade &snapped a few pics of the contraptions i made to ever so carefully remove the existing brushed motors/fans. BTW, ive seen a lot of good ideas in the thread to remove the fans from motor, but dude, mine werereally on there!!! Even covered the engine nacelles with paper towels to protect the paint & still ended up with a few scuffs to be touched up. Another BTW, saw somewhere on eBay an adapter(sleeve)kit with aluminun extention to fit brushless 2.3 or 3mm motor output shafts. If i recall,extention secures to the brushless output shaft by set screws & comes with a newfan too.
Oh well, while A-10 is grounded, its to windy (for me) outside to fly, anyway.
ID:	1431403   Click image for larger version
CochiseSignal8 is offline
Old 07-10-2010, 03:56 PM
  #977
Olliee7
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Could anyone please provide me with the suggested center of gravity for the A-10 Thunderbolt 2 aircraft.
Olliee7 is offline
Old 07-11-2010, 05:19 PM
  #978
Olliee7
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I read your comment about center of gravity for this aircraft. I am concerned with the initial position of the center of gravity due to the pusher configeration and high thrust line. Could you give me an idea of the inital center of gravity you used and about how much elevator displacement you used. Any help you cn provide would be greatly appreciated.
Olliee7 is offline
Old 07-11-2010, 06:04 PM
  #979
canwhitewolf
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I tried to work it out the CG mathematically and with graphs, I cant guarantee what i say is accurate but may give you a starting point
I calculated the CG to be about 1"- 5/8" to 1-3/4" back from leading edge at wing root
as to elevator i read somewhere that one should Move the control horn to the innermost hole on the elevator servo horn, and the outermost one on the horn on the elevator, but i havnt buiilt my plane yet so cannot guarantee any of this
perhaps someone else has another opinion
good luck
canwhitewolf is offline
Old 07-13-2010, 05:52 PM
  #980
Olliee7
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
canwhitewolf
Thanks for the input
Olliee7 is offline
Old 08-17-2011, 05:25 AM
  #981
sergiozaki
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Guys
I have a guanli RC A-10 55mm , brushless ,11,1v 1800mha , hes nice and it fly very good with no wind
But there is one problem , the wire landing gear are very weack ,not so strong when i land .
What do you recomend?
(sorry my english)
sergiozaki is offline
Old 08-23-2011, 11:53 AM
  #982
Kmot
My Feedback: (24)
Kmot's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
My last previous post in this thread was on page 25!
My Guanli A-10 with brushed motors has been collecting dust since the end of 2008. I decided to try and fly it today.
All stock, except for a 1450 mAh 3S lipo. And the batteries in the 72Mhz transmitter had leaked and so I threw it in the trash and installed an OrangeRx receiver on 2.4Ghz into the model.
I fly at Apollo XI field in Los Angeles and it has a long runway.
Well the plane that is not supposed to fly, does.
It was marginal, yes. Slow climb out, I got it up to about 50' and made one circuit of the pattern and then came in for a landing. I did not want to push my luck and go fetch it in the bramble bushes if the motors siezed up. [X(]
But I just wanted to pop in and say that "yes, the stock brushed motor version can indeed fly under its own power."
Kmot is offline
Old 08-29-2011, 04:48 AM
  #983
sergiozaki
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
heyyy
Its good to know that someone still  fly with A-10 R\C brushless
Normaly i go to an airfield to , my A-10 need speed before take off
He only fly with no wind, i already tried the 1800  mah 11.1V  he fly
belive me.
On the landing  sometimes my landing gear brokes and your?
(sorry my english)
Old 09-05-2011, 10:47 AM
  #984
sergiozaki
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Guys
My english is a mess so il give a try
I have a A-10 55mm ( twin engines , Twin ESC) I bought 2 4200KV engines and 2 Turnigy 30A Plush ESC
to use with a 11,1V 2200mha battery , pls Help.
I have a Y conector to conect both ESC to RX , I have to disconnect 1 red wire from one ESC?
I have a program card to setup turnigy ESCs , what setup i should use?
Thanks in advance
Old 11-24-2011, 12:54 PM
  #985
Dongskie
Dongskie's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks!
Glad I found this thread
Dongskie is offline
Old 11-24-2011, 03:01 PM
  #986
Tony Iannucelli
My Feedback: (193)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
My A-10 flys like a trainer, looks cool in the air, and lands gently. It doesn't eat batteries either. I like it.
Tony Iannucelli is offline
