Great Planes L-39
#51
RE: Great Planes L-39
Can a brushless motor of a larger diameter be used? I have an Align 430L with a 3550KV value that is used in a T-Rex 450X heli.
It has a diameter of about an inch...is an outrunner with alot of power.
Does anyone have any pictures of how the motor is mounted in the ducted fan unit?
Thank you,
Michael
Thank you,
Michael
#52
My Feedback: (7)
MO
Here's a link to the instruction manual for the hyperflow fan unit. It's got some pictures that show how the motor will mount in the fan unit.
[link=http://manuals.hobbico.com/gpm/gpmg3910-3911-manual-v1_1.pdf]hyperflow manual[/link]
As far as putting a bigger can motor in, I don't think you can do it with this particular unit, the largest diamter it will take is 24mm and that's with some dremel work to open up the housing a little for it to fit. In order to do a brushless outrunner your gonna have to get an adapter for it.
The first pic is an adapter, the second is of an adapter mounted to an outrunner, and the third is an assembled unit in a ducted fan.
#53
I used to have a Park zone styker and flew it with no problem. Is the Great Planes L-39 any harder to fly then the styker. Also, can you fly the L-39 and a slow speed or will it stall. What about flight times.
#55
My Feedback: (7)
MO
ORIGINAL: frankaarthur
ORIGINAL: blitzskiff
hey what do you guys think about this set up: LINK
#56
MI
ORIGINAL: gr8taz nitro
I don't think you would have any trouble flying one. It flys pretty slow, but keep in mind it takes a little bit for the power to come back up if you do stall it out.
That's not too bad. Basically it's a stock plane with the rest of the stuff you need to get it airborne. The 900 mah battery isn't gonna do much in the way of flight time but it'll be a pretty lightweight setup.
"If bullets bounced off supermans chest, why did he always duck when they threw the gun at him?"
The bullet weighs 158 grains assuming it's a 38SPL (and that's what it looks like and was common for the time), the pistol weighs 2 to 3lbs.....hummmmmm, I'd duck, LOL, it might give the man of steel a black eye or something (couldn't resist).
#57
tried to get it to fly....won't go on step...at 4800 feet... just won't climb.... rds 8000 radio, 1500 miha 20c bats....crash hard once and im not a beginer..any help?
#58
MI
ORIGINAL: motobud269
#59
#60
hey what do you guys think about this set up: [link=http://www3.towerhobbies.com/cgi-bin/wti0161p?&I=LZ2061**]LINK[/link]
#61
MI
ORIGINAL: The_Russian
Don't do it! Use S3156MG servos and a bigger ESC and battery. If you really want to go fast, get a 24-45-3790 motor.
#62
My Feedback: (7)
MO
#63
My Feedback: (7)
MO
Original: crashcrash
Hey......thanks for answering these guys. As I think of questions I have, you hit the answer for me....Thanks. One thing on your signature line....LOL:
I've had a lot of people on here help me out, answering questions and it's only right to pass it on. Any info I give tends to be slanted by my own personal experience, but if I can help someone else out, I'm glad to do it.
#64
MI
LOL I've seen some of the old man of steel shows in history class.LOL I'm young enough that Christopher Reeve is the first one I saw. I just thought it was too funny that the bad guy would shoot, and he'd stand there and take it, then when the bad guy ran out of ammo( this predates the hollywood never ending ammo gun), he'd throw the gun and superman would duck!!!!
I really think the guy in Colorado is fighting "thin air". Bigger fan, bigger batteries...MORE WEIGHT...it's a loose-loose situation I think. In Michigan, a real HOT day and low humidity make for a poor flying day because the air molecules are less dense. If it's humid and hot, the plane makes use of the water in the air, flying is about normal because of the water molecules. I've had it 96% humidity and NOT raining, the model comes back WET with droplets on it.
#65
MD
Did the same thing over the winter, nasty misty day, flew my MUS, plane started flying sloppy assume the battery was dying. Landed and realized the thing was covered in ICE. It was pretty cool to see how the ice affect the flight characteristics. Makes you understand why the stuff is so dangerous to small general aviation airplanes.
#66
NY
You're the first person I heard who had a problem like me. I'm no beginner, but don't have much DF experience. I thought it was screaming during the run up, but the best I could get from a hand launch was a controlled descent. I kept trying to the point of breaking a wingtip. After I glued the wingtip back on, I had gotten some newer batteries (I was using 1300ma 3 cell, but they were low C and had small red connectors) I now had deans connectors and the runuo still seemed the same. I decided to put in a bigger esc. Changed from an 18 amp to a 30 amp, and then found out what a screaming DF sounded (and felt!) like. Then it flew like a banshee until I got too far out, lost orientation and put her in. After glueing the pieces back on, it now looks like frankenplane, but I intend to fly it again.
#67
MI
ORIGINAL: Azzir325
Yeah, the books says 25a ESC....I think minimal would be 30a ESC, and I also think minimal would be 1800 mAh 20C...IMO.
#68
OH
I FLEW MY L-39 THE OTHER DAY ,IT TRACT VERY NICE ,SOUNDS GREAT TO.
USE HIGH RATE ELEVATOR SETTINGS AILERON YOU CAN LEAVE LOW RATE.
MY FIRST LAUNCH WASN'T VERY GOOD AT ALL,NOT ENOUGHT ELEVATOR, HIT THE GROUND LEVEL BUT KINDA HARD. FUSE CRACKED BEHIND COCKPIT. CA TIME.
BE VERY CAREFUL ON HARD LANDINGS , THE COCKPIT AREA IS A WEAK STRUCTURE AREA.
I GLASSED THE INSIDE.
I DON'T KNOW WHEATHER TO OVERHAND OR UNDERHAND THIS JET ,ANY ADVICE WOULD BE NICE.
IM USING 1500 3C ELECTRIFLY
25 AMP EFLITE SC
THIS JET DOES FLY NICE , THINKING ABOUT A CANOPY UPGRADE.
25 AMP EFLITE SC
#69
Hi all, flew mine last weekend, around 4500 ft agl 15deg. C, 1800 mah FP, C.G. came out on front limit,45A sc, tested the 3500kv at full throttle 17.2A, very dissapointing performance, battle for altitude and 80% power to hold,between 3/4 and full throttle only the noise changes.... rolls nice and fast but thats it, no other EDF knowledge, what is the best hopup? 3790 or 4875 kv? wanna keep 11.1 v setup. The Russian seems to have it sorted but i'm in that weight vs altitude battle...
#70
My Feedback: (7)
MO
ORIGINAL: boneviator
#71
Thanks a lot gr8taz, plan B is 2x 1345's EVO lites 2s in series, it'll save me 50g as well, on the 3500 kv motor and 14.8V it seems like the best combination, if not ill find out how not to do it....
#72
Thanks everyone for the input. I moved the battery back a bit to make it slightly tail heavy. After a very hard overhand launch i finally got it to fly. WOOW. Still a bit sluggish, same as the other guy i have to fly at 3/4 to full throttle. but none the less its flying and i have made several flights now, quess it's time for the hop ups!!! can't wait to take it to a lower elevation when i go on a trip
#73
Unbelievable!!!!!
The girlfriend went across the street to babysit for her sister, so I took the dog out to the field next to my house and gave the L-39 a go.
WOW!!!!!!
The setup:
24-45-3790 Ammo Inrunner
SS-45 Electrifly ESC
4S 1500mAh 25C Flightpower LiPo
S3156 Digital MG Aileron Servos
HS-65 Elevator Servo
AR6100 Spektrum Radio setup
The method:
Overhand launch
Half-hungover
95 deg OAT at Sea Level
The Outcome:
This setup brings the aircraft to life. My first setup was stock with a 30a ESC and a 3S 2250 25c Loong Max. Boooooooo!!! That thing was fun, but it was a dog. Although I never had any problems launching overhand style, the plane did fly nose heavy. The new setup launches and climbs out at half power, thats all it takes. The aircraft is tail heavy, which will allow me to possibly install an 1800 4s for higher flight times.
The first two flights were incredibly fast and I only flew for 3 minutes for battery break in. I was afraid to fly it with a power setting of over 50% because there was so much power available. At 50% it was difficult to keep in sight because of the sheer speed. Loops and vertical flight are now effortless. Unlimited vertical so far, although I have not flown straight up with full power yet. I'll wait until I am comfortable before I try. Acceleration is almost instant. I did try one 100% burst, but backed off immediately as it shot way from me. Top speed will be well over 100mph or even 150mph with this setup.
I performed the same cooling mod that the other guy posted on RC Universe, but my electronics were still hot after both flights. (OAT is 95F so that might have some influence)
Disappointments:
The airplane is still very difficult on approach and landing. The grass destroys the beautiful plane more on every landing and it also eats away at the leading edges of the wings. I put scotch tape on the leading edges for extra protection. There are still green marks all over the bottom. She wont be good enough to display very soon.
Good luck! Videos to come!
WOW!!!!!!
The setup:
The method:
Overhand launch
Half-hungover
The Outcome:
Disappointments:
#74
The Electrifly design team needs to take a look at those aileron and elevator foam hinges. They are VERY weak. Another method of hinging the control surfaces will be needed soon.
#75
MI
