jetscreamer motor question???help
My Feedback: (20)
PA
ok talked to little screamers about this issue and i had to email them my setup so while thats being looked at heres the issue, the motor works great till half throttle, after that it chatters as if its out of time, flys the whole pack fine at half throttle though, esc is electrifly ss-25 with timing locked at 12 degreed, pack is a electrifly 3S 1500mah 15C pack, motor should be drawing 14 ampd wide open according to them so the esc and battery should handle it...so whats wrong with it???
My Feedback: (12)
RE: jetscreamer motor question???help
ORIGINAL: Vertical3-D
Scott
www.ModelAero.com
My Feedback: (20)
PA
ok, just ordered the pentium 30amp from DONS RC, it has adjustable timing, and start modes, hopefully that works, cause 30 bucks sure beats 70 for an 18amp jeti esc, if it doesnt run the motor I'll probablly send it or the motor back...
