Go Back  RCU Forums > Electric Aircraft Universe > Electric RC Jets
Reload this Page >
EasyTiger Models Tigerline X-29 Build
Electric RC Jets Discuss rc electric ducted fan or radio control prop jets here.
Old 04-19-2009, 01:07 PM
  #101
mpope1
Default RE: EasyTiger Models Tigerline X-29 Build
Nick I lost mine today, I think the cg is way off. It got it the air, I was pulling back on the elevators but not at full, it climbed out nice but once I went to make my turn it nose dived and elevator wasn't pulling it out. When I went to turn, I naturally loosen up on the elevator so the plane wont turn to tight, and just that little bit put it in a nose dive. That seems nose heavy to me. I think the cg should be measured from the leading edge of the canard not the intake lip.
Old 04-19-2009, 04:16 PM
  #102
frisconick
Bummer Mike. We're Oh for two ! Did you seem to have enough air speed so it wasn't a stall condition? Did you have to hold a lot of UP to keep it flying once it left the ground? How was it at the point of rotation? Did you put the bigger nose wheel up front? Still debating on whether to try another one of these.
Nick
Old 04-19-2009, 05:10 PM
  #103
mpope1
It had sufficent air speed, did put a bigger nose wheel. Rotation was fine, felt real nose heavy once it was in the air. I would leave this one alone, hopefully Bob has better luck, but even with the cg right it will still be a handful.
Old 04-19-2009, 08:51 PM
  #104
bruff
My Feedback: (18)
bruff's Avatar
Here is the video of Mike's flight attempt.
http://www.rcgroups.com/forums/showt...5#post12062732
Bob
Old 04-20-2009, 06:05 AM
  #105
frisconick
I tried watching it yesteday, but my player would only give the audio. Will try to figure it out later; and how to post mine.
Nick
Old 04-20-2009, 06:10 PM
  #106
bruff
My Feedback: (18)
bruff's Avatar
You will need a Dixv codec for the video to play.
Bob
Old 04-21-2009, 10:39 AM
  #107
frisconick
Mike,
Yours did lift off a lot smoother than mine and looked like it was going to be OK. In the begining of the video, it looked like you had more elevator throw than I did. Were you set for the 15mm up/down? Maybe with elevators and canards, it really doesn't need that much movement once airborne. I had quite a bit of expo dialed into mine for that first flight (or takeoff) for that very reason.
Not sure what's next for me.
Nick
Old 04-21-2009, 08:30 PM
  #108
mpope1
I had about 17mm on the canard, and maybe 18-20 on the elevator, but I had a lot of expo dialed in. I was showing Bob my high rates also. That was a lot more maybe what caught your eye in the vid. I kept it on low the whloe try.
Old 04-22-2009, 09:45 AM
  #109
frisconick
Here's a link to the maiden......
http://www.rcuvideos.com/video/X-29-Maiden-wmv
Nick
Old 04-22-2009, 02:53 PM
  #110
bruff
My Feedback: (18)
bruff's Avatar
Looks like Mike's also. I'm going to use the CG that Daren worked out. Should be just forward of the wing tips.
Bob
Old 04-22-2009, 02:57 PM
  #111
frisconick
Good luck Bob. I hope you prove him right ! What program/system does he use?
Nick
Old 04-22-2009, 03:04 PM
  #112
Arbo
ORIGINAL: bruff
Bob
I think you will find that is the answer.
Old 04-22-2009, 04:57 PM
  #113
PhilLin
bruff, that's what Arbo told me in the first place. But I also remember he did not have too much luck with his smaller x-29 last time around. At any rate wish you luck.
I must have misplaced & forgot about the folder with my X-29 Nitro & Hasegawa manuals at our last club meeting. Hope someone decide to return it.
Phil
Old 04-22-2009, 05:05 PM
  #114
Arbo
As a ducted fan, you are correct. I believe it was thrust line issues back then. I later flew that airframe on the slope a few flights (crunchy things don't last long around here) and it flew fine. The canards were fixed and I used delta wing mixing for the controls.
Old 04-22-2009, 10:56 PM
  #115
angelrcdesign
My Feedback: (40)
Did the real have a 2+ deg. on the conard?
Old 04-23-2009, 09:12 AM
  #116
PhilLin
ORIGINAL: angelrcdesign
Don't know about the full scale. But if you look at mpope1's sideview pix, there seem to be some positive incidence on the foreplane.
I like your bottom note about "try & try again", but to the Irish tune:
........Oh Donnie boy, the packs the packs are costly,
........The radio too, they certainly are not cheap.....
Cheers,
Phil
Old 04-26-2009, 10:54 PM
  #117
flyingplumber68
at least the x-29 looks a hell of a lot better than the supercat . still deciding whether or not to use the flimsy ducting or to use balsa to make a custom duct to fit around my tp-pro power 30c 3300 mah 4s so the plane can be balanced. let me know if you have tried the supercat or not, just wondering because i was deciding on the x-29 or the sabre as my next jet if this one works out just want some outside input other than from curtis.
Old 04-27-2009, 04:44 PM
  #118
bruff
My Feedback: (18)
bruff's Avatar
X-29 1st flight is this Tuesday. Hopefuuly the 3rd is the charm.
Bob
Old 04-27-2009, 05:47 PM
  #119
frisconick
I'll be there in spirit Bob.
Keep the shiny side up !!
Nick
Old 04-27-2009, 10:53 PM
  #120
bruff
My Feedback: (18)
bruff's Avatar
ORIGINAL: frisconick
Nick
Did you ever contact Easytiger about the CG problem? Nitromodels is taking care of Mike Pope after his crash.
Keep you posted about tomorrow.
Bob
Old 05-03-2009, 12:08 PM
  #121
bruff
My Feedback: (18)
bruff's Avatar
I flies! See http://www.rcgroups.com/forums/showp...&postcount=251
Bob
Old 06-26-2009, 07:51 PM
  #122
Burt-RCU
My Feedback: (23)
Anyone have easy tigers email????
Old 06-26-2009, 10:07 PM
  #123
dw_crash
Curtis Mattikow
[email protected]
Best of luck,
DW_Crash
Old 06-27-2009, 03:24 PM
  #124
Burt-RCU
My Feedback: (23)
Burt
Old 07-05-2009, 08:40 PM
  #125
sparkola
So what is the final verdict on the CG? measured from where and how far back?
