6S power from two 3S lipo's
IN
Quick question...I need to get 22.2 volts (6S) from two 11.1 volt lipos (3S)......Do I make a adapter wired in series or parallel?? This electric stuff is new to me so I need some advice here.....Thanks,...........A diagram, directions or even a pic would be helpful as well....[8D]
AL
RE: 6S power from two 3S lipo's
Series....you can purchase a series adapter for a few bucks from your LHS with Deans connectors. Just plug your batteries into the adapter, then plug the single lead from the adapter into your ESC pigtail. The Deans is the most common...they should have others also.
