Sapac Comp Hawk
Sapac Comp Hawk
can someone tell me if the stated c of g of 140-145 mm back from the bottom of intake is correct on this plane
as it seems very nose heavy for rotation with the landing gear installed
thx
Daryl
thx
Daryl
RE: Sapac Comp Hawk
that sounds great Ron,mine seems quite heavy with the 4000mah pack,how much runway do you use?
I was thinking of bending the main struts forword towards the CG to help with rotation,my field only has about
300' of pavement
Daryl
300' of pavement
Daryl
My Feedback: (22)
RE: Sapac Comp Hawk
Daryl ,
Rotation is not a problem .. I fly mine with a 4s 4200 and 5000 mah pack so your just fine with the 4000 mah..
but I will say 300' is going to be tight to land on... I've got maybe 60 flights on mine and I would have a hard time stopping on 300 ft.
it can be done .... but becarful
I fly at three site ones 1000' , 600 and 400
I use up most of the 400 on landing... maybe 200 to take off...
if you can use a longer site to get used to it that would help
I fear if you try and get it slow enough to stay in the 300' you'll stall.. so watch your speed
if it starts to wing rock give it some power
I hope it works out well for you.. keep us posted
later
Ron
later
Ron
RE: Sapac Comp Hawk
no flaps on this one as well,if I can set her down on the pavement then role off into grass probably be ok
hope the gear will stand up
