Banana Hobby.Flight Review of the Ultimate BlitzRCWorks B-2 Spirit Bomber!
CA
RE: Banana Hobby.Flight Review of the Ultimate BlitzRCWorks B-2 Spirit Bomber!
Any one else find pete's "reviews" dubious at best? Never believe a vendors flight review, they are more skewed than magazines reviews. If you were selling these, would you put in your review the problem with bad servos and bad retracts and all the other issues bh is famous for? Maybe you would, but bh sure doesn't. Wait and read reviews from real users before spending that much coin on a piece of cooler foam, then decide if it's worth it or not. Just saying...
BC, CANADA
True. I was impressed with the speed of it for a stocker. But the price as you mention is quite high for a molded hunk of foam. I dont care how big it is, the foam cant cost more than 20 bucks between a 25" span versus a 60" span.
The ad states 100% satisfaction gaurantee, but I don't know what value that holds. Now all servos in just about ANY RTF are questionable, and do have a higher failure rate than a big name brand, But I have had decent luck with my 3 sets in different birds. knock on wood.
CA
I've had good luck with the stock electronics from BH and Nitroplanes..... But nowI buy air frames ONLYif available.
I just bought one jet from a different vendor and two (2) servos did not come...One of the servos issupposeto be reverse and is NOT, getting that one off it's been a B-ash with out messing up the foam, but hey, I took my chances and here I am....
CA
I'm sorry but I have not started my built. I haven had the time the build needs but here's a link I've been following. Its got really good info.
http://www.rcgroups.com/forums/showthread.php?t=1110081
I just recieved the blitzrcworks J-3 electric 90% RTF from Banana hobby and there was NO INSTRCTIONS for the 10% I need to build!!
and I can't seem to get ahold of anyone at BH Does any one have a set or info to get through to BH
