Electric RC Jets Discuss rc electric ducted fan or radio control prop jets here.
Yellow Aircraft F-16C EDF Build
Reply
Old 06-20-2012, 08:37 PM
  #201
Wisdumb
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Yellow Aircraft F-16C EDF Build
Installing the ESC, going over placement, a little bit of heat shrink, and some capacitors!  Action packed indeed!
[youtube]http://www.youtube.com/watch?v=cvbD3_sNcW4[/youtube]
Wisdumb is offline
Old 06-28-2012, 05:04 PM
  #202
Wisdumb
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
EPISODE #69
Exciting stuff in this one!  Check it out!
[youtube]http://www.youtube.com/watch?v=boLnPW3yNPA[/youtube]
Wisdumb is offline
Old 06-30-2012, 09:19 PM
  #203
Wisdumb
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Check out the latest installment.  Some VERY exciting stuff in this one.  Let's just say that I should be able to do some taxi tests tomorrow weather permitting. :-)
[youtube]http://www.youtube.com/watch?v=4W-YWz4YDtU[/youtube]
Wisdumb is offline
Old 07-01-2012, 08:22 PM
  #204
Wisdumb
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ok, I got a chance to taxi today!  Check out the video to see.
I do have a small issue with the wheels not tracking.  The grub screws to keep the wheels pointed correctly don't seem to keep them in place.  I think I'll either need to get inside and file a flat spot, or maybe make a hole and tap it?… I'll figure it out.  Hopefully nothing too in depth.
[youtube]http://www.youtube.com/watch?v=ZAI30_GFOKc[/youtube]
Wisdumb is offline
Old 07-02-2012, 05:45 AM
  #205
juanjulian
juanjulian's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Very goog editing.
Think a flat spot should domthe trick.
Fallowing.
Cheers
Juan
juanjulian is offline
Old 07-03-2012, 11:54 PM
  #206
Wisdumb
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Late night episode!  I fixed the gear problems (Tracking and brakes.)  Check it out in the video:
[youtube]http://www.youtube.com/watch?v=JZDCWEDVV08[/youtube]
Wisdumb is offline
Old 07-07-2012, 07:41 PM
  #207
Wisdumb
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I tried again the flying field today and the brakes work fine. I think I like the solid braking better than the "anti-lock."
Dave at the flying field helped me get my radio programmed so that the brakes are activated when I put in about 40%-50% down elevator. I just couldn't get it to activate. It turned out all that was to crank up the sub trim some.
While testing the brakes we noticed it started listing to one side. I thought that was strange. When we brought it back to the bench we noticed one of the bolts that attaches the gear to the bulkhead was gone! Doh! I checked the other bolt and it was loose as well. I was planning on going through and applying loctite to everything later, but maybe sooner than later is better
We found the bolt on the runway and put it back in.
One last "that sorta sucks" moment was when I wanted to test the non anti-lock braking. The balsa block I have holding the pushrod tube in place for the nose steering busted loose from the fuselage. I'll make another with some ply and hysol in place.
It's hot and miserable so I'm not sure how much progress I'll make this weekend.
Wisdumb is offline
Old 07-17-2012, 06:23 AM
  #208
Wisdumb
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here's some canopy building action!
[youtube]http://www.youtube.com/watch?v=IhStjW8Itm8[/youtube]
Wisdumb is offline
Old 07-18-2012, 05:36 AM
  #209
Wisdumb
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Canopy Buildin' Action #2 (It moves!)
[youtube]http://www.youtube.com/watch?v=g7xNWnGxdCc[/youtube]
Wisdumb is offline
Old 09-06-2012, 03:43 PM
  #210
Wisdumb
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I'm back!
[youtube]http://www.youtube.com/watch?v=PVE_TlyJYOI[/youtube]
Wisdumb is offline
Old 09-09-2012, 12:43 PM
  #211
Wisdumb
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here's the completed aileron torque rod assemblies and some aileron movie' action.
Note: Be sure when you install the brass tubes on the inside that they do not protrude past the wooden servo tray… I had one that had about 1/8" protrusion and it made it so that I could not put on the aileron because none of the hinges would line up.  I had to grind it down to make it work.
[youtube]http://www.youtube.com/watch?v=brYpxs0Owd0[/youtube]
Wisdumb is offline
Old 09-23-2012, 02:49 PM
  #212
Wisdumb
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quick video update.  Some stuff for sale, skip to 3:25 if you don't want to see that.
[youtube]http://www.youtube.com/watch?v=MLtIoBaNT0I[/youtube]
Wisdumb is offline
Old 09-30-2012, 12:18 AM
  #213
Wisdumb
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Working on finalizing the ailerons.  I had to add caps to the ends to cover the hole I had to make to get to the torque rod "sleeve" that fell inside.  I only need to glass the one aileron since I did the other a looooong time ago.
[youtube]http://www.youtube.com/watch?v=ugwhB36yT8I[/youtube]
Wisdumb is offline
Old 09-30-2012, 06:41 PM
  #214
Wisdumb
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Continuing finishing the ailerons.  Here is a glassing video for those of you interested.  I didn't speed anything up so those interested can see the process from start to finish and the technique.
[youtube]http://www.youtube.com/watch?v=u6-2J7TOvTk[/youtube]
Wisdumb is offline
Old 10-02-2012, 11:56 PM
  #215
Shaun Evans
Shaun Evans's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Wisdumb
Yeah,
You're supposed to adjust the wheels to your desired toe-in and grind a flat spot on the top of the wire to set it. Glad you did that.
Shaun Evans is offline
Old 10-03-2012, 10:24 PM
  #216
Wisdumb
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yeah, I finally figured it out... someone else also posted that the grub screw was at the top, not the bottom... doh! It was no wonder I couldn't get them to stay put!
Wisdumb is offline
Old 10-03-2012, 10:26 PM
  #217
Wisdumb
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sorry guys, I couldn't help it… I had to try out those dry transfers from aeroloft… and I love those things! They were a little tough around the curved surface and I had to work out some wrinkles, but man does it look good! I'll make a video next time I swear! (The wings are pretty close to being ready to paint, so it won't be long&hellip
Wisdumb is offline
Old 10-05-2012, 07:26 AM
  #218
Ro
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Looking forward to getting one of these from Yellow aircraft / S. Evans!
Ro is offline
Old 10-05-2012, 11:38 AM
  #219
JustFlyIt
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I am so ready to see this bird fly.
JustFlyIt is offline
Old 10-05-2012, 09:21 PM
  #220
Wisdumb
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here's part 3 of episode #77.  This one's packed full of glass weave filling dry transfer scratching' mayhem!
[youtube]http://www.youtube.com/watch?v=6kWnkh87jWk[/youtube]
Wisdumb is offline
Old 10-06-2012, 08:44 PM
  #221
Wisdumb
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here's the last of the aileron finishing.  I have to say I really think the bondo spot putty and acetone brush on technique to fill the weave is the way to go.  It sands so easy and gives a good finish.  I also think it saves on weight.
[youtube]http://www.youtube.com/watch?v=cAAmq_WpkPY[/youtube]
Wisdumb is offline
Old 10-07-2012, 07:15 PM
  #222
Shaun Evans
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi,
Nice finished product. Have you ever tried thinning the resin and brushing it through the cloth with a paint brush? I cut Z-poxy 60/40 with denatured alcohol (more alcohol than resin). I lay the cloth onto the part and brush the mixture straight through. It's considerably faster if you ever want to give it a try. I can get both sides of all of the wood surfaces on this F-16 glassed in about 2.5 hours on a sunny day, and one of those hours is just for drying time.
Old 10-07-2012, 07:33 PM
  #223
Wisdumb
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Time to start prepping the missile rails for paint. I primed them and am in the process of eliminating the seam with some bondo spot putty.
Something tells me these would look much sweeter with some missiles attached!
ID:	1809124   Click image for larger version
ID:	1809125   Click image for larger version
Wisdumb is offline
Old 10-07-2012, 07:36 PM
  #224
Wisdumb
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Can anyone provide a link to some good walkarounds or decal placement for all the "no steps" and "dangers" and whatnot? If anyone has some pics of the Fort Smith Alabama ANG Razorbacks that would be awesome. It is proving to be much more difficult than I thought it would.
Wisdumb is offline
Old 10-07-2012, 07:41 PM
  #225
Wisdumb
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: YellowAircraft
Hi,
I have tried that, it works good. I was too lazy to go down to the garage to get the denatured alcohol. Thanks for the suggestion. I'll do that for sure when I do my next one on all surfaces, it does go much faster.
Wisdumb is offline
Reply
Display Modes
