Go Back  RCU Forums > Electric Aircraft Universe > Electric RC Jets
Reload this Page >
ElectriFly F-20 Tigershark EDF
Electric RC Jets Discuss rc electric ducted fan or radio control prop jets here.
Old 05-30-2010, 05:53 AM
Greg Covey
Greg Covey's Avatar
Default RE: ElectriFly F-20 Tigershark EDF
Jon,
Congratulations on your successful test flights. I noticed that you flew with the missiles mounted. Did you glue them on or just use the stock magnets? On the older L-39, the manual said the wing pods were for show but I ended up flying with them anyway. I was intending to try the missiles on my second flight but maybe I'll just leave them on.
I re-scaled my F-20 yesterday as well. I have a group of friends I call the "Scale Police" because I hear about it every time I miss something on a review.
My F-20 test flights are today so I'll report back tomorrow.
Old 05-31-2010, 07:40 AM
Greg Covey
Greg Covey's Avatar
We had some very successful flights with the F-20 Tigershark. The jet really moves out so it gets small fast! After the first flight, I moved the pack back about an inch and it flew true without any elevator offset. I will re-measure the CG soon and take another pack position photo.
I firm hand-toss is needed to get the model airborne. The Tigershark performed loops and rolls with ease but inverted flight was a bit difficult with the flat bottom airfoil. The missiles had no problem staying put during flight but we lost one or both when touching down in the grass.
I'll post a video soon along with some more flying photos...
flying photos by "Papa Jeff" Ring
ID:	1445562   Click image for larger version
ID:	1445563   Click image for larger version
ID:	1445564   Click image for larger version
ID:	1445565   Click image for larger version
ID:	1445566   Click image for larger version
ID:	1445567   Click image for larger version
ID:	1445568   Click image for larger version
ID:	1445570   Click image for larger version
ID:	1445571   Click image for larger version
ID:	1445572   Click image for larger version
Old 05-31-2010, 08:15 AM
barnesjonr
Bravo Greg ... looks like you folks also had some great times on your initial flights!
Old 05-31-2010, 10:17 PM
barnesjonr
More flights today on my F20. Ilike it. Flew some pretty slow circuits for the camera but also like the way it moves out at WOT. The high power to weight ratio helps keep hand tosses from going any way but great.
ID:	1446105   Click image for larger version
ID:	1446106   Click image for larger version
Old 06-05-2010, 06:45 PM
Greg Covey
Greg Covey's Avatar
The maiden flight of the F-20 Tigershark was captured on video. To my surprise, the wing tip missiles stayed in place during flight and only came off on landing in the grass. Pilot, Lynn Bowerman, did a good job keeping an eye on the EDF as it gets small very fast at full throttle. The F-20 slows up nicely and remains stable at a wide range of speeds.
I'll post some photos next of the new battery pack position and included display stand.
[link=http://www.gregcovey.com/reviews/F20Tigershark.wmv]F-20 Tigershark Maiden Flight Video[/link] (12meg)
ID:	1448354   Click image for larger version
ID:	1448355   Click image for larger version
ID:	1448356   Click image for larger version
ID:	1448357   Click image for larger version
ID:	1448358   Click image for larger version
ID:	1448359   Click image for larger version
ID:	1448360   Click image for larger version
Old 06-08-2010, 06:50 PM
  #31
Greg Covey
Greg Covey's Avatar
Shown here is my new position for the battery pack. It was moved about an inch back and moved the CG aft by about 3mm.
The supplied display stand assembled easily with 5-minute epoxy. You can also use white glue buy not CA.
ID:	1450285   Click image for larger version
ID:	1450286   Click image for larger version
ID:	1450287   Click image for larger version
Old 06-21-2010, 07:06 PM
  #32
mithrandir
mithrandir's Avatar
Nice.. how many flights?
Old 11-14-2011, 11:47 PM
  #33
srt10
My Feedback: (20)
I know this thread is well over a year old, but is this jet worth getting or is there something better in this price range??
thank you
ps. I saw this today at my Hobbytown and it looks cool
Old 11-16-2011, 11:39 AM
  #34
1turnWonder
I have both the L-39 and the F-20, superb little planes that handle very well, easy to control and tough too, aerocell is the best foam material around.  The F-20 could be very fast, I flew it on 4-cell and oversized outrunner motor which ruined the little fan unit after 3 flights.
The L-39 is a beauty to look at, I have the clear canopy version
Go for these planes, they're well worth it
Old 11-16-2011, 01:27 PM
  #35
srt10
My Feedback: (20)
ORIGINAL: 1turnWonder
thank you for your comments!
the F-20 is my favorite jet and I'm thinking of making this my first EDF
I have several Nano 2200mah 4s packs that could work awesome in this little Jet
and 85mph out of the box aint bad.. [:-]
maybe 100mph with just a little faster motor on a bigger esc..
Old 11-17-2011, 12:24 PM
  #36
1turnWonder
This is the Cyclone motor I fitted into mine, it's meant for 64mm fan
Old 11-17-2011, 04:38 PM
  #37
srt10
My Feedback: (20)
what's the kv of that motor?
Old 11-17-2011, 10:27 PM
  #38
1turnWonder
http://rc-castle.com/shop/product_in...oducts_id=1613
Cyclone Power CS450-4500-30EDF Motor
Features :
- New Design High Performance EDF Motor
- Outrunner Section Exposed In Air Stream For Better Cooling
- With 180 Degree High Temperature Magnet Wire For Winding
- With N45SH Strong Magnet To Provide The Motor With High Torque Performance
- With NMB Bearing For High RPM Application
- Dynamic Balanced
- Suitable For Mega Power 55mm Ducted Fan , GWS EDF64 Ducted Fan , Freewing 64mm & Other 55 - 65mm Ducted Fan Unit At 11.1v - 14.8v Setting
Description :
- Outside Diameter : 28.0mm
- Total Length : 68.0mm
- Weight : 93g
- Motor Shaft Dia : 3.0mm
- Kv : 4500 rpm / V
- Power : 850W
- Working Voltage : 11.1v - 14.8v
Test Data:
GWS EDF64 (6 Blade) + CS450-4500-30EDF Motor + 11.1V Static Thrust: 730g 36A
GWS EDF64 (6 Blade) + CS450-4500-30EDF Motor + 14.8V Static Thrust: 1100g 54A
Freewing 64mm Ducted Fan (5 Blade) + CS450-4500-30EDF Motor + 11.1V Static Thrust: 710g 35A
Freewing 64mm Ducted Fan (5 Blade) + CS450-4500-30EDF Motor + 14.8V Static Thrust: 1100g 53A
Old 11-17-2011, 10:54 PM
  #39
srt10
My Feedback: (20)
wow, that should move very well!
Old 11-24-2011, 03:06 PM
  #40
Tony Iannucelli
My Feedback: (193)
My stock F-20 is a great plane, no pun intended. It moves out, is easy on batteries, lands reasonably slowly, and looks very cool in the air. I even use the rockets in flight. I launch off a catapult, and it it a very neat way to go. Tower has this now for $89 before coupons which is a really nice price. The red paint has worn off in spots, and it still looks good. Tony
Old 05-01-2012, 05:31 AM
  #41
Mustangman40
Mine just came in at my LHS........ Some good tips in this thread........
