Velocity-RC WM400MkII
As we expand our EDF product line, we are pleased to announce that we are now a Australian and New Zealand supplier for the WM EDFs and Velocity RC motors.
We will be working along side Claus and Anthony to provide you the WM400 mkII (70mm) and the WM300 (60mm) EDFs and related products.
They will provide information regarding performance specifications.
The unit below is the highest power of the 70mm EDF setups, as available, ready to assemble and install.
Here are the specs that have been provided to us at this time.
Thrust...2500g (5.5lb)
efflux....345kph (214mph)
Watts...1900-2000 (burst)
Amps....105-110
RPM......54K
Lipo......6s (For 5s..1500w)
Motor....2600kv, 29-56mm, 4mm shaft
Optional motor:
For 4s;....700w, 3400kv, 29x40mm, 3.2mm shaft
For 5s.....1500w 3200kv, 29x56mm, 4mm shaft
Both motors fit the WM400 mkII (70mm) and the WM 300 (60mm) EDFs.
FSA info:
velocity WM 300 mkII have FA 2827mm2 FSA 2023mm2(Ø=51mm)
Velocity WM 400 mkII have FA 3848 mm2 FSA 3044mm2 (Ø=62mm)
The rotor is designed for smooth running out of the mold and is dynamically balanced for fine tuning..
This is a high quality products professionally made and not just bits from various manufacturers stuck together and called a fan..
find out more at [link=http://www.southerncrossrc.com]Southern Cross RC[/link]
Amps....105-110
RPM......54K
Optional motor:
FSA info:
RE: Velocity-RC WM400MkII
Please ensure that you are buying an authentic WM400Mk2 and not the older Mk1 or cheap asian clone...
As these cheap copies cannot handle the same level of power that the real WM400Mk2 can..
My Feedback: (10)
PA
Hello all, I got my MK-2 set up from efflux RC motor and fan is 120.00 plus shipping. The Velocity MK-2 70mm 6S motor and fan is one mean set up. I tested it today as I just got in my 6s 40C 4000 pack yesterday. All I can say is wow!!!!!![X(]
Here is what I got on my Hyperion watt meter. Could not get the RPM's as I was inside the house and the light was not right to get a reading. But if you go by the formula of 22.34 X 2900 Kv=64,786 rpm's and smooth as silk not a rub at all.
22.34 V
94.75 Amps
2116 Watts
Keep em flying
raido56/ Herb
22.34 V
94.75 Amps
2116 Watts
Keep em flying
raido56/ Herb
OH
Hello Rorock,
The WM 4XX Fans from www.Ductedfans-RC.com are authentic We were the investor that made the fans possible through are old partner Andy Pang of Toy Werkz now called Velocity-RC. As to our WM fans being able to take power http://www.ductedfans.com/media/PDRM0011.AVI. We have run ours on 10s, and we have maybe done more testing on them than anyone else. I find little difference in the MK1 or MKII as far as performance.
PS all the Velocity WM fans are made in China / Asia. The soon to be released WM 480 VX 3 is made in Ohio, USA, as the partnership between Ductedfans-RC and Velocity has dissolved.
The WM fans are worth a look.
I will dig up more test vids or check here http://www.ductedfans.com/videos.html.
I have just received a velocity-rc T-33.. Will be a doing a build thread here on it, powered by a WM400mkII on 5s..
EPF trailing link DSR retracts..
I recently finished a Velocity-RC T-33 running 5S on the BL2856 3200kv motor. Nice jet!
[youtube]http://www.youtube.com/watch?v=C2nagc-hOXw[/youtube]
