Duct Fan Turbinator
My Feedback: (12)
RE: Duct Fan Turbinator
There are no plans for one however LDS can cut you an enlarged one and you can get the plans enlarged at Kinkos or Stapes. A WWII canopy from Sig should work as well. i started one at 150% for a 120 fan last year got tied up with work and stopped right after I cut out all the parts
Bob,
LDS are laser design services, some great guys who do laser cutting of parts..
Here is images from my currently assembly of a 70mm artf turbinator..
Rob
Rob
Bob,
Have you had any luck with the 70mm e-turbinator plans at all?
I can check around, I think they were provided by one of the US mags at one stage...
Rob
Rob
Model Airplane News had the plans and a construction article. Link to the plans purchase http://www.airagestore.com/planes/turbinator-e.html
Cheers!
Barry
Cheers!
Barry
Well I've gotten a bit more of the e-turbnator built..
I've cut out the covering over the retract section.
I've test fit the 9g metal gear servos.. They needs the servo mounts open slightly lengh ways.
And test fit the flying surfaces prior to building..
Rob
Rob
