RCU Forums
RCU Forums (http://www.rcuniverse.com/forum/)
-   Electric RC Jets (http://www.rcuniverse.com/forum/electric-rc-jets-198/)
-   -   What's a good set up for a 90mm EPO (http://www.rcuniverse.com/forum/electric-rc-jets-198/11269570-whats-good-set-up-90mm-epo.html)
xcz5785 10-20-2012 07:08 AM
Curious what set up might be good for a 90mm foam jet. I have a 90mm EPO foam F86, 60in WS, 88oz. It's in kit form now. I need ESC, motor, servos, etc. I have a fan but was thinking about a Change Sun 10 blade. I want it to have plenty of power and sound as scale as possible.
Downwind3Zero 11-06-2012 02:27 AM
RE: What's a good set up for a 90mm EPO
For "plenty of power and good sound" I would recommend a JetFan 90 +  a HET motor. There are other choices too (Stumax, etc.)
Chris
xcz5785 11-07-2012 01:55 PM
I have located a thread for the NitroPlanes F-86 Kit I have. The consensus is a JetFan 90, Het 700-60-1865Kv motor, Castle 100a ESC with BEC, 6s 5000 MAH 30C lipo. I think I'm going with that. Ive seen good numbers and the sound is very turbine like. Thanks for your inputs Guys!
ACES&8s 01-20-2013 01:52 PM
I'd like to recommend that the 5000 mah 6 s pack be a NanoTech 65c. Batteries are the important part!
6.8 pounds thrust...plane 5.5 pounds plane. Nice!
Extreme_RC 01-21-2013 03:08 PM
The Jetfan rotor is an excellent choice,I am running the 700-60-1865Kv motor with Jetfan rotor in the Extreme Alloy housing, runs around 3.3-3.4kg thrust at 2200 watts on 5000 6s 35c packs, and gets my new Mirage moving along nicely. Its not as efficient as a 90mm Wemo Midifan but it has a different sound. Here is my Mirage:
[youtube]http://www.youtube.com/watch?v=FpHj8Dr6pRo[/youtube]
ACES&8s 01-22-2013 03:54 PM
Great having big wide open space to fly! The performance of the Mirage is great too!
Extreme_RC 01-23-2013 03:44 PM
Yup our club field is looking good right now, although off the south end there is a massive patch of blackberries about 30m wide and hundreds of meters long, you dont wana go landing in there! http://www.rcuniverse.com/forum/js/f...n/drowning.gif
sidgates 09-03-2013 07:27 PM
Quote:
XCZ,
I wondered if you finished the
F-86D and flew it??
