E-Flite Super Airliner - parts ??
Vertical Fin Assembly: Super Airliner
by: E-flite Avg. Customer Rating: (0) Item: EFL7003 Does anyone know where I can find this discontinued part? With this part, I can build the rest of the plane. Thanks everyone |
Hi TTMT,
What you may have to do is cut a new one out (Hot Wire Cut)out of foam to replace the one you are missing. I have a whole new airframe and the Vertical is not really a sophisticated item. The new one I got for e-flite came to me damaged but. is easily repairable. Carlos G |
Thanks. I laminated three layers of foam together and fabricated a vertical tail from the profile of one of the elevators. I made a nice hinged rudder and fitted it to the fuselage. It looks great and I'm sure it would work well.
Problem is, the main wing and engine mounts are no longer available. I can't finish the plane after-all. Thanks again. TTMT |
