Blohm & Voss 215
Hello. Am new to def foam jets. Need help cutting foam, with a foam cutter thanks Rich |
I use sharp Stainley knifes to start with, for more complex curve cuts get yourself a hot wire cutter.https://cimg2.ibsrv.net/gimg/www.rcu...58ef2e3bac.jpg
First draw, next cut out. |
Blohm & Voss 215
Hello got foam cutter. Building Blohm & Voss 215. Have you seen one of these?What to build the tail pipe out of? Rich |
https://cimg7.ibsrv.net/gimg/www.rcu...f88f4d60e7.jpg
I rolled this one today, double layer X-ray film. I use "Mylar" , if spelled correctly, plastic sheeting that comes in all sorts of thickness. For smaller jobs like my current made tube (X-29) I use large X-ray film sheets, sometimes I double them, depends on the power. We have a business in Austr. "Plastic Factory", selling anything you like plastic. |
Tailpipes
Great! Do you have a paper catalog? What’s your website? Where are you located? Thanks Rich |
Rich, sorry, you have miss understood, it's not my business, as said 'we have in Aust.' You might have the same outlets in where ever you live, check it in yellow pages under plastic supplies.
Tailpipe
where do I get Mylar from? |
https://cimg5.ibsrv.net/gimg/www.rcu...b264585580.jpg
New tubes roll out. From any plastic supplier. Just rolled out couple of tubes today for my "Twin Widow", this time in the 'blue mood'. |
