HET F-16 2W-20 and tsunami 72A ESC questions
I am building a HET F-16, What kind of watts and amps will I be drawing at full thottle with a HET 2W-20, 72 amp esc and a 3000 Miamp 4s Lipo rated at 20C cont 30C max. battery?
Lot of experience with Turbine and DF but new to the electric jet thing. Thanks, Matty |
RE: HET F-16 2W-20 and tsunami 72A ESC questions
ball park
2W20 HET 6904 Fan 4S3000 20C lipo: 39,600 rpm, 700 watts, 49.30 amps, 14.20 volts 4S4700 25C lipo: 41,600 rpm, 836 watts, 55.8 amps, 14.98 volts Some have achieved better numbers but that all depneds on conditions. HET paired the 72amp ESC because of the performance drop if a 45 or 60 ESC heats up when not in the EDF air flow. It says this if you got the kit. If you need to bump that up a little go to Don's site www.Donsrc.com and try the BI-3600. Just check what adapter size you have or need to match up. |
