Electric Training If you are new to electric learn more about them here or ask questions.
Rimfire / Multiplex Cularis
Reply
Old 12-05-2010, 02:01 PM
epoxy123
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Rimfire / Multiplex Cularis
Was looking to make use of a Rimfire .10 35-30-1250 and was wondering if someone can tell me if this will work in the Multiplex Cularis? Thanks!
epoxy123 is offline
Old 12-05-2010, 06:01 PM
Dr Kiwi
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Rimfire / Multiplex Cularis
As long as you take, with all the grains of salt in Siberia, the suggested amp/watts limits for the Rimfire 35-30-1250 [35A/333W... get a grip!]. In my testing I found that the motor could cope with 25A... maybe a bit more... but it didn't like anything close to 30A, let alone 35A; at those levels it was unable to hold amp draw or RPM, and attempting to fry itself.
On 3s it did well enough with a 10x6 GWS HD, but a 10x7 APC E was a bit much, and an 11x5.5 APC E was over the top.
At 71g, and applying the 3W/g rule of thumb... 210W-220W is okay... maybe push it to 250W... but I wouldn't go much further.
Dr Kiwi is offline
Old 12-06-2010, 05:17 PM
epoxy123
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks Doc. I got the grains of salt in Siberia but the rest was sketchy LOL
So the Rimfire will work on the Cularis?
epoxy123 is offline
Old 12-06-2010, 08:50 PM
Dr Kiwi
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If 250W is enough, and you don't need bigger than a 10" prop... sure it will.... but I suspect that such a large plane might be better off with a bigger folder (12"-13"?)... and thus a bigger motor.
I see some reviews etc that indicate ~60oz weight and the stock powerplant is a HC3522-700 400W motor with a 12x6 folder.... I fear your Rimfire won't cut it.
Dr Kiwi is offline
Old 12-07-2010, 06:12 PM
epoxy123
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
bummer...thanks Doc.
epoxy123 is offline
Old 12-23-2010, 08:17 PM
aeajr
aeajr's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have this same motor in my Dust Devil.  I have it running a 10X7 prop on 3S lipo for about 290 watts and it does just fine.  I also run it with an 11X8 on 2S lipo for about 200 watts.
Should do fine in a Cularis with a 10X7 or perhaps an 11X6, but I have not tried the second one.
aeajr is offline
Old 12-26-2010, 03:04 AM
epoxy123
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
that is encouraging news , thanks aeajr!
epoxy123 is offline
