Electric Training If you are new to electric learn more about them here or ask questions.
new to elect and motor wont run
Reply
Old 12-07-2010, 12:54 PM
Mtthwacrss
Mtthwacrss's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default new to elect and motor wont run
Okay I got my first electric plane an Ikarus SU27, It was set up with a Motor Max 400F 15 A motor and a 30A speed contorler. a Hitec micro 05S receiver. I am using a JR7202 Radio. Battery is fully charged. How do i set this up for my radio. My throttle is on channel 3.The motor came on when I was at the sale but now since I moved it to 3 I get nothing from the motor. the ailerons and elevator work fine set up on delta. As I said I am new to electric and don't have a clue on how to get this to work.
thanks for any help you can give.
Matt
Mtthwacrss is offline
Old 12-08-2010, 11:54 AM
Glacier Girl
Glacier Girl's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: new to elect and motor wont run
Matt, I believe JR is channel #1 for throttle. Hitec and Futaba Tx's use channel #3 for throttle.
Even if you are using a Hitec receiver, you will need to plug the esc lead into socket #1 not #3 on the receiver to work with your tx.
Glacier Girl is offline
Old 12-08-2010, 12:54 PM
Mtthwacrss
Mtthwacrss's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
On my radio throttle is channel 4 the 3 was a typo. I am getting nothing on from the engine at all. No beeps, no start, Nothing. Any ideas??????
Old 12-08-2010, 05:43 PM
Jetdesign
My Feedback: (8)
Jetdesign's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Check your throttle end points. Maybe the ESC is never arming?
Jetdesign is offline
Old 12-09-2010, 05:56 AM
Mtthwacrss
Mtthwacrss's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
How do I do that. Before I got the radio set to the right band and changed the connections on the receiver when I hooked up the battery the motor would beep and start running, now nothing.
Old 12-09-2010, 07:46 AM
Jetdesign
My Feedback: (8)
Jetdesign's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Can you please clarify (just so I can understand and maybe help):
1)..."got the radio set to the right band". What did you change, and why?
2) What was the setup "at the sale" when the motor came on and everything worked? Was it your radio?
Old 12-09-2010, 07:57 AM
Mtthwacrss
Mtthwacrss's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
First at the sale it was not my radio. I have a Jr. 7202 and I didn’t have it set to PCM when I first tried it, but I did have the right channel set. Then I realized I needed to change the servos around as my throttle is on #4. After I made all the right connections the elevators and ailerons work fine when set to Delta. But I get nothing from the electric motor no matter where I plug it in. when I first tired it the motor would beep and then start running but I had no control. I hope this helps you to help me.
Matt
Old 12-09-2010, 08:25 AM
Jetdesign
My Feedback: (8)
Jetdesign's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks.
First things to check are:
1) make sure your throttle trim is all the way down and see if that does anything, then 2) try reversing the throttle channel.
My gut feeling, which could be wrong, is that your thorttle is not giving a "0 throttle" signal to the ESC, which I believe it needs to see to arm (safety feature so that the motor doesn't just start spinning when you turn on the receiver).
Then I would check end points. If this is a computer radio (looks like one with the screen on the bottom) you need to go in and access the end point function. I don't use JR so I can't tell you how off the top of my head, but if works stays this slow I'll do some research.
Old 12-09-2010, 08:26 AM
Jetdesign
My Feedback: (8)
Jetdesign's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
this looks like a link to the programming:
http://www.horizonhobby.com/ProdInfo...rogramming.pdf
Old 12-09-2010, 08:58 AM
Glacier Girl
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
As stated channel #1 on the rx is throttle socket on the receiver if you are using a JR radio. If you look at the programming info posted above it shows the listing of the channels.
Channel#4 is for the rudder.
Something else, any chance you just have the esc lead plugged in backwards into the receiver?
Old 12-10-2010, 02:00 PM
Mtthwacrss
Mtthwacrss's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It is pluged in right I set my trim all the way down and it sitll wont arm the motor. I will keep looking this weekend and see if there is something else I can set in the programing to make it work.
Also after looking at my radio and book you are right chanel 1 is the throttel, I got confused as it was set up on 2 3 and 4 when I got the plane and didn't have it wiht me when I was typing my first post.
Sorry
Matt
Old 12-12-2010, 08:57 AM
Jetdesign
My Feedback: (8)
Jetdesign's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Make sure your throttle endpoint is at its minimum setting (-100 or -150 or something).
Old 12-13-2010, 05:32 PM
Glacier Girl
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Also a couple of other things. Some of these cheap esc have an arming button that needs to be pushed in to arm the esc. Usually a little red button on the bird fuselage.
And I've also seen where you have to power up the tx, then the rx, then move the throttle to full, wait for a tone, then back to off, and then the esc arms.
Old 12-14-2010, 12:45 PM
Mtthwacrss
Mtthwacrss's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Got it going.Thanks all.
Matt
Old 12-15-2010, 05:05 PM
Glacier Girl
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Well do tell what was it?
Old 12-15-2010, 09:13 PM
Mtthwacrss
Mtthwacrss's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
To tell you the truth I'm not sure. I think the last thing was setting the throttle travel again and it worked.
Old 08-03-2011, 10:44 AM
Mtthwacrss
Mtthwacrss's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Okay I hit the wrong reset on my radio and wiped my Su27 info off and now my motor won’t run again. Of course I had not written it down yet when this happened. I have the throttle (L 125 on the sub trim, travel adjustment is -150, trim full down.) set to its lowest setting Just got a new charger for the battery and it is charged. Anyone have a good idea???
Old 08-03-2011, 11:17 AM
levram1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I do! Take up another hobby, about like I am about to do!! LOL
levram1 is offline
Old 08-03-2011, 01:37 PM
Mtthwacrss
Mtthwacrss's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Naaa I don't have any trouble with my gas planes.
Old 08-03-2011, 05:51 PM
acdii
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I thought all ESC would beep when plugged in, but unless had 0 throttle input, wouldn't go through the arming process.  I had that with my t-28, wouldn't spin up until I talked to HH support and found out my trim was too high. My Eflite Apprentice now wont arm unless I use down trim on the throttle, even though it is all the way down. Try just bumping the throttle trim down to see if it eventually arms.
I'm not familiar with your radio, but if its computerized like the Spektrum DX6i, then try a new profile and use the default settings for setting up the throttle channel, then once you have that, set the rest up.  Oh and dont hold the trainer switch when turning it on next time! Did that once, once.
acdii is offline
